Timing Chain Replacement
Old 11-20-2009, 04:36 AM
lblair04's Avatar
lblair04
lblair04 is offline
Default Timing Chain Replacement
Whats the point of replacing the timing chain while im doing aps plenum kit/water pump? If its not loose or anything, is it worth changing. Or is it one of those preventative maint things at 92k miles on a 00 1500 4x4 w/360?
Just curious...
Old 11-20-2009, 06:37 AM
97black_ram's Avatar
97black_ram
97black_ram is offline
Just preventative maintenance since you'll already have half the front end apart for the water pump.
Old 11-20-2009, 07:19 AM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
at 92K yours will be loose.
Old 11-20-2009, 07:58 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
the timing cover is a big gigantic thing with integrated water cavities. so the timing cover gasket is a potential (and fairly common) coolant leak.
also, it gives you a chance to replace the front crank seal. and its only $40-50.
Old 11-20-2009, 08:20 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
Its a very simple job if you know mechanics. (obviously) The plenum is easy to change as well. Dont buy another gasket for plenum or you'll be changing it again, go to http://hughesengines.com and search for the plenum re-enforcment kit. you wont have to worry about the plenum again.
Timing chain all depends. my truck has 195K when i did the water pump and checked the chain it was tight, and no wear. (PO was a mechanic and i think he changed it) So check it out at least, and with that many miles its probably the stock, you should upgrade to a double roller chain.
Old 11-20-2009, 10:14 AM
dsertdog56's Avatar
dsertdog56
dsertdog56 is offline
You don't have to change it...hell you don't even have do the plenum if you don't mind adding oil and all the other issues.
Theres a quick way to determine if you should. Crawl under the truck, grasp the crank pulley/balancer with both hands and try to rotate it. If you feel a "clunk" or play (thats the chain slack against the valvetrain) and you can rotate more that an 1/8 inch to get that, you should replace it. As stated it can only get worse.
Worse meaning it will throw off your PCM because your cam sensor and crank sensor are not in sync, among other timing issues. At worst, it could break or come off when all the nylon teeth on the cam gear disintegrate. The carnage at that moment can vary, but running a valve into a piston isn't much good on either component.
So why not check it, change it, and replace a couple of potential high mileage leaks as well. Just sayin...
Old 11-20-2009, 10:20 AM
Gary-L's Avatar
Gary-L
Gary-L is offline
This. Always think ahead, because the nickel you aren't willing to spend now could cost your dollars in the long run.
Old 11-20-2009, 03:32 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
OP said he was getting the APS kit.
I know when I do the plenum kit, I am definatly changing the timing chain. May also do the water pump and camshaft.
Old 11-20-2009, 03:39 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
when i change my chain, im putting on a double roller at te same time putting on some 1.7's...but thats after i get the first portion of my rebild out of the way, then its front end, and thn ill do chain
Old 11-22-2009, 10:06 PM
lblair04's Avatar
lblair04
lblair04 is offline
How hard is a timing chain to replace? If I do it, I will go to a dual roller chain, but doesnt that make it thicker? Is there enough clearance with the stock timing cover?
Big question: can I mess it up pretty bad if I have never done a timing chain before? I am pretty mechanical...just never a timing chain...
Thanks
Quick Reply: Timing Chain Replacement
