Transfer Case Fluid Type
Old 11-18-2009, 01:50 AM
discnik's Avatar
discnik
discnik is offline
Default Transfer Case Fluid Type
Do you use the ATF +4 in the 241 transfer case ? It is a Ram 2500 with the 5.9 Cummins, 4 X 4.
Thanks in advance
Old 11-18-2009, 02:00 AM
J415's Avatar
J415
J415 is offline
click here: https://dodgeforum.com/forum/2nd-gen...apacities.html
Old 11-18-2009, 02:30 AM
1fast2liter's Avatar
1fast2liter
1fast2liter is offline
link is broke
Old 11-18-2009, 07:00 AM
95RAM360's Avatar
95RAM360
95RAM360 is offline
it worked for me, but i copied and pasted the fluid capacitites
CAPACITIES
Engine oil, with filter
V10, 8.0L - 7 quarts [1]
V8, 5.9L - 5 quarts
V8, 5.2L - 5 quarts
V6, 3.9L - 4.5 quarts
Cooling System, Initial Fill
V10 - 26.5 quarts
V8 - 20 quarts
Automatic Transmission, 46RE Initial Fill..........4.1 quarts
Automatic Transmission, 47RE Initial Fill..........4.1 quarts
Automatic Transmission, Total Fill
4 speed 46RE..........11.7 quarts
4 speed 47RE..........17 quarts
Manual Transmission, NV1500.................................4.7 pints
Manual Transmission, NV4500.................................8.1 pints
Manual Transmission, NV5600.................................9.6 pints
Manual Transmission, NV3500 4WD..........................4.3 pints
Manual Transmission, NV3500 2WD..........................4.9 pints
Differential, 4WD With Dana 44 Front (216-FBI).........4.8 pints
Differential, 4WD With Dana 60 Front (248-FBI).........8.5 pints [3]
Differential, 2WD With Dana 60 Rear (248-RBI)..........6.4 pints [2]
Differential, 2WD With Dana 70 Rear (267-RBI).............7 pints
Differential, 2WD With Dana 80 Rear (286-RBI)..........6.8 pints [4]
Differential, 4WD With Dana 60 Rear (248-RBI)..........7.5 pints [2]
Differential, 4WD With Dana 70 Rear (267-RBI)..........7.7 pints
Differential, 4WD With Dana 80 Rear (286-RBI)........10.2 pints
Transfer Case, NV241HD W/ PTO..........................10.4 pints
Transfer Case, NP231, 233....................................2.6 pints
Transfer Case, NV242, 244....................................2.8 pints
[1] After refill check oil level.
[2] Fill no higher than 3/4 inch below plug hole.
[3] Fill no higher than 1/4 inch below plug hole.
[4] Lube level in all axles must not come up to the fill plug
opening. The level must be as follows: FRONT
with 7.25 inch ring gear, 3/4 inch (17mm);
with Dana 44, 1/4 inch (6mm);
with Dana 60, 1/2 inch (12mm). REAR:
with 7.25 inch ring gear, 1/2 inch (12mm);
with 8.25 inch ring gear, 1/4 inch (6mm);
W/ 9.25 inch ring gear, 5/8 inch (15mm);
With Dana, 3/4 inch (17mm).
Old 11-18-2009, 11:36 AM
95MaroonMonster's Avatar
95MaroonMonster
95MaroonMonster is offline
yea, just ATF + 4, it's what i have in my case, and the 241 ain't much different, except bigger
Old 11-18-2009, 03:26 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
Yeah, use ATF+4.
And the reason for that is, if the seal(s) between the transmission and transfer case start to leak, the transmission fluid wouldnt become contaminated with a different fluid.
Change the Transfer Case fluid every time you change the Transmission fluid.
Old 11-18-2009, 05:07 PM
Miami_Son's Avatar
Miami_Son
Miami_Son is offline
Originally Posted by PurplDodge
Yeah, use ATF+4.
The previous spec, ATF+3, is compatible with ATF+4.
This is a question that could have easily been answered by doing a search.
Quick Reply: Transfer Case Fluid Type
