DIY - Burping your Coolant System
Old 06-06-2009, 12:49 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Thumbs up DIY - Burping your Coolant System
For anyone who has never done it, here's how:
Add a mixture of one-half water and one-half antifreeze to the radiator. Fill it right up to the top.
Fill the overflow/coolant reservoir with the same 50/50 mixture.
Leave the radiator cap off, turn the engine on and let it run until the radiator "burps": You will see the coolant level drop and may see or hear a large air bubble come to the top as the system burps.
Keep an eye on the temperature gauge throughout this process.
Refill the radiator to the top and coolant reservoir as needed.
Note that if the engine runs hot after this procedure there may have been another pocket of air that "burped." Let the engine cool down and then add more coolant to both the radiator and the coolant reservoir. Don't just assume after the first try that you got all the air out...
Lynn Wells (06-28-2020)
Old 04-28-2013, 02:52 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Just to add some info. Raising the front passenger side of the truck, will also help in burping the system. Hope this helps.
The following 2 users liked this post by zman17:
Lynn Wells (06-28-2020), tavandy (04-04-2020)
Quick Reply: DIY - Burping your Coolant System
