Help!! P000B Where is the sensor
Old 11-11-2009, 04:45 PM
smilley's Avatar
smilley
smilley is offline
Unhappy Help!! P000B Where is the sensor
Someon help Please i had a check engine light come on and went to autozone to get it scanned. It came up with Exhaust (b) Cam position sensor slow response. I would like to find out wher this is located so i can change it. Pics would be nice. I would like to change myself without spending a crap load of money. Ive look all over the internet and nothing that shows me. Some please can you help me out.
thanks smilley
Old 11-11-2009, 05:11 PM
eaglestorm's Avatar
eaglestorm
eaglestorm is offline
I think there is a flash for cam sensors it's poss you are using the wrong oil or it's just dirty the sensors are picky there is a lot more to it than just a sensor swap. the problem with having codes checked at autozone or parts places is yes they tell you the code and the system but that dont mean it's a part failure could be wiring,connectors. a pcm or program problem I look up your car cant find a flash available but to be sure you can have the dealer ck it with wiTech and it tells us what flashes your car needs
Old 11-11-2009, 05:16 PM
smilley's Avatar
smilley
smilley is offline
I got the oil changed. I would like to change the sensor and then rule that out then move on to the next protental problem.
Old 11-11-2009, 05:41 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Did you reset the code and it came back? I would do that first if not to see if the code returns.
What engine do you have? I think they are all basically the same in the Caliber and the cams are in the head so the sensor should be too.
What is the exact code that you got?
Old 11-11-2009, 06:13 PM
smilley's Avatar
smilley
smilley is offline
yes i did reset it and the light still came on and the code still came up P000B and it says exhaust (b) cam position sensor slow response. engine is a four cylinder.
Old 11-11-2009, 09:13 PM
bigtsr's Avatar
bigtsr
bigtsr is offline
Go look at these pages from the Caliber parts/service manual.
https://dodgeforum.com/forum/members...-to-files.html
Old 11-11-2009, 10:31 PM
smilley's Avatar
smilley
smilley is offline
Thank you so much bigtsr. That helped out alot. My wife wants to drive it by this weekend and i wanted to change them out before she goes. Hope that works. If not ill just go down the line to see what is next. Thanks
Old 02-17-2015, 02:33 PM
kpoints's Avatar
kpoints
kpoints is offline
Default 2007 dodge caliber p000a , p000b
my 2007 caliber does the same thing . is all changes all that could be wrong , or something else
Old 02-22-2015, 07:19 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
I would try replacing the sensors if the codes keep coming back.
Quick Reply: Help!! P000B Where is the sensor
