Rear Axel Speed Sensor / Rear ABS Sensor DIY
Old 11-10-2009, 12:08 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Default Rear Axel Speed Sensor / Rear ABS Sensor DIY
This will cover the instructions on how to replace the Speed Sensor/ABS Sensor located on the top of the rear differential. Most common side effect of no Speedometer and ABS illuminated light in the instrument cluster on the dash board. This is a very easy repair.
Disconnect the upper electrical harness if the new sensor comes with a new extension. If the sensor did not come with on (as mine did) then disconnect the harness at the sensor.
2. Using a 1/2" deep socket remove the nut holding the sensor in.
3. Next pull out the emergency brake cable clasp and brake line clasp out of the sensor cover. These are tabbed so grasp the back side of them and pull up slightly then pull the front side out. Tip the clasps out of the way (straight up).
4. Place a 9/16" deep socket down the bolt shaft to contact the 2 sided bolt nut at the bottom. Remove this bolt.
5. Pull the sensor cover off the sensor. On the front of the sensor there is a little tab so pull slightly while removing.
6. Clean loose dirt and rust off area before removing the sensor so nothing falls into the differential contaminating the fluid.
7. Twist the sensor and then wiggle it back and forth while pulling it straight up.
Now it's reinstall time. Remember to lubricate the seal on the new sensor with fresh gear oil and lubricate the whole in the top of the differential before installation.
Installation is in reverse order and just snug the bolt to about 35 lbs and nut to about 25 lbs.
Old 03-24-2010, 09:04 PM
WheresMacGyver?'s Avatar
WheresMacGyver?
WheresMacGyver? is offline
Just got my Durango from the shop yesterday- they said it needs a new ABS sensor and want 200bucks to replace- diagnosis was 125- so that would take it up to 325 total- I said no- glad I found this thread!! Thnx again Hydrashocker!
Old 03-24-2010, 10:01 PM
Trapstud's Avatar
Trapstud
Trapstud is offline
Holy **** Batman I think they just tried to rape you!!!!!!
Old 03-25-2010, 01:04 AM
hydrashocker
Thumbs down
Um..........NO!
Old 03-25-2010, 10:48 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
im confused hydra, NO what?
Old 03-25-2010, 11:49 AM
Trapstud's Avatar
Trapstud
Trapstud is offline
I'm confused as well. $125 for diagnosis is double what the cost is in my neck of the woods. The sensor is only $30 or so and labor is only about an hour. It seems to me like they were going to charge wheresmacgyver? double what it should really cost.
Old 03-25-2010, 04:45 PM
hydrashocker
Meaning I'm not into mental rape!.......
Old 03-25-2010, 04:49 PM
Trapstud's Avatar
Trapstud
Trapstud is offline
Old 03-25-2010, 08:31 PM
shrpshtr325
THE ULTI-MOD
well noone here is into mental rape, but that doesnt mean it cant happen to people
Old 03-25-2010, 10:53 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Man that is a lot of rot and rust!
Quick Reply: Rear Axel Speed Sensor / Rear ABS Sensor DIY
