Power outlet fuse
Old 10-30-2009, 08:25 PM
BeachBoy's Avatar
BeachBoy
BeachBoy is offline
Default Power outlet fuse
Anybody know where the fuse is for the power outlets on a '00 durango 4.7? The cig lighter works fine. Can't find the sucker. Nothing else is not working. Thanks.
Old 10-30-2009, 10:07 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
The fuse is in the PDC, thats the black box under the hood. Check all fuses with a 12v test lite, thats because most of the time you can't see the fuse blown.
Old 10-30-2009, 11:53 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
the one in the dashboard of my truck is actually fused in the fuse panel in the driver side door jam, the fuses are all labelled
Old 10-31-2009, 08:55 AM
BeachBoy's Avatar
BeachBoy
BeachBoy is offline
Tiebreaker anyone? Haven't seen the label fo this circuit either place, and haven't had the motivation to check each fuse w/ a meter.
Old 11-01-2009, 03:08 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
I don't have my info right now but look in the dash fuse box. I'm sure you'll find it. THe back of the cover has a diagram on it.
Old 11-01-2009, 04:39 PM
calmc's Avatar
calmc
calmc is offline
There is a fuse block by the driver side kick panel, that block has fuses front and back and the fuse is on the back. Look above your emergency brake. That fuse is for your power outlets in dash and rear cargo area.
Old 11-02-2009, 07:11 PM
BeachBoy's Avatar
BeachBoy
BeachBoy is offline
Maybe I'm a big dummy, but I did not know there were fuses on the back side of the block, those sneaky little boogers. That sounds like it, I'll check tomorrow.
Old 11-02-2009, 07:36 PM
shrpshtr325
THE ULTI-MOD
iv actually never seen the fuse block thats supposed to be on the back so gl finding it
Old 11-10-2009, 07:22 PM
BeachBoy's Avatar
BeachBoy
BeachBoy is offline
Sure enough, there's four fuses on the back side, and the 20A is for the power outlets. God knows what the other three are, but worth a look if you ever can't find an electrical break. Thanks for the help. Now I can go back to running the satellite radio, GPS, cell phone, Ipod, DVD. Maybe I'll get a blender for the rear outlet.
Old 11-10-2009, 11:02 PM
hydrashocker
And you wonder why you blew the fuse?
Quick Reply: Power outlet fuse
