99 2500 cummins fuel filter canister leaking fuel
Old 10-29-2009, 01:20 AM
jsmith2260's Avatar
jsmith2260
jsmith2260 is offline
Default 99 2500 cummins fuel filter canister leaking fuel
the head of the fuel filter canister is leaking around the heating element and the dealer is the only avenue to get a kit to fix the problem.......$1200.00
any suggetions on a less expensive approach?? any advise or help would be appreciated.
Old 10-29-2009, 07:27 PM
pizzo's Avatar
pizzo
pizzo is offline
well if you need a new fuel filter housing? change it with a fass or a airdog they are less then that price. www.doghousediesel.com tell him Pizzo sent you for your pricing and he will help you out with what ever you need
hope that helps Pizzo
Old 10-30-2009, 11:25 PM
jsmith2260's Avatar
jsmith2260
got it fixed for now. replaced the o-ring and no leaks yet. http://www.cumminsforum.com/forum/98...ilter-tip.html great tip.
Old 11-01-2009, 07:29 PM
pizzo's Avatar
pizzo
pizzo is offline
Sorry dude the way you typed it out sounded like the housing was cracked or something if that happends the just put a fass or airdog on it but Oring was bad???
Old 11-02-2009, 09:09 PM
jsmith2260's Avatar
jsmith2260
yep it was dried out and had cracks in it. we will see how long this lasts.
Old 11-02-2009, 09:44 PM
pizzo's Avatar
pizzo
pizzo is offline
yeah well every time you change your fuel filter you should change the O-ring also
Old 11-03-2009, 10:44 PM
jsmith2260's Avatar
jsmith2260
it was the o-ring on the fuel heating element not the one on the fule filter
Quick Reply: 99 2500 cummins fuel filter canister leaking fuel
