Trans band adjustment help?
Old 10-27-2009, 09:21 PM
ladodgerfan's Avatar
ladodgerfan
ladodgerfan is offline
Default Trans band adjustment help?
I have a 1999 dodge ram 1500 slt 5.9L and I need help on how to adjust the bands on my tranny.
From start to finish please..I hope this works cause i wanna start driving my truck again.
thanks david
Old 10-27-2009, 10:26 PM
ET RAM's Avatar
ET RAM
ET RAM is offline
I can only give you a general idea how to do it. My manual only goes to 1998. First you need a manual to get the adjustment information. You have to determine which transmission model you have then look up info. Plan on changing the transmission fluid and filter. You have 2 bands a front and rear. The front adjustment screw is on the left side of the transmission on the outside. The rear screw is inside where the pan is located.
What you do is loosen a lock nut. Then you tighten the adjusting screw to a given specification. Once there, you have to turn the adjusting screw back the number of specified turns. Then you torque the locknut.
As an example a 1998 model with an 46RE transmission:
Front band, tighten to 72 in-lbs and back off 2 7/8 turns
Rear band, tighten to 72 in-lbs and back off 2 turns
Torque locknut, Front 30 FT-lbs
Rear 25 Ft-lbs
Then you change the filter, install the pan and gasket and fill it with fluid.
Again, get the specifications for your transmission.
Old 10-27-2009, 11:23 PM
ladodgerfan
thanks for the info
Old 10-27-2009, 11:53 PM
xray99's Avatar
xray99
xray99 is offline
All kinds of info here on band adjustment.
https://dodgeforum.com/forum/search....archid=1245567
What kind of symptoms are you experiencing that you think adjusting the bands will help ?
Not really something you do just for the heck of it, you stand to do more harm than good if you make the slightest error adjusting them.
Old 10-28-2009, 12:41 AM
ladodgerfan
well this all started a year ago trying to remember what really started all this crap but know when i have it in drive going about 20 mph and if i increase the spead the rpm's just keep climbing between 2000 to 2500 or higher but it dont drive any faster.. also it whines when the spead increases
I've had a local tranny shop look at it and they said i needed a rebuilt cause they couldn't get it to go into gear but it shifts fine in all gears
feels like it is still in a lower gear at 20mph or its restricted i just am frustrated
Old 10-28-2009, 01:03 AM
xray99's Avatar
xray99
xray99 is offline
Well, maybe someone else can comment on those symptoms, theres alot of good tranny guys here who have been through the mill and back with these trannies.
You need a snap-on scan tool hooked up while driving, that might just tell you everything you need to know.
Some tranny shops have them and wil scan for free, others may want $25 or so.
Might also work to run a craigslist add in services wanted "looking for snap-on scan tool" and see if you can get someone local to hook one up for a small fee.
Old 10-28-2009, 01:11 AM
ladodgerfan
ya have someone dropping by tomorrow to scan it for me
Old 10-28-2009, 02:32 AM
Laramie1997's Avatar
Laramie1997
Laramie1997 is offline
Someone will surely correct me if I'm wrong, but that whine usually either means clutch pack clatter or something in the vlavebody. I don't think a band adjust is going to help any if at all.
I know mine whines at cruising speed when you are under acceleration, but it's done that for the last 70,000 miles and I trust the old guy that rebuilt it saying it was common to hear that sound when he rebuilt one. Apperantly he does something funky with the shift kit that he buys to use. I'm not sure what, but every tranny that I've seen him rebuilt is done well the first time. Only times he's had one come back is when some idiot doesn't know that neutral drops= bad.
I'm not saying yours is normal. Don't read wrongly.
Oh, you might consider getting onto JC whitney's site and looking at their OBDII scanners. You can pick one up that will scan 2008 and below vehicles for about $300 or less. I opted for the higher end one just for the fact that it will monitor the on board sensors. Great for trouble shooting. You could also find an older model on ebay fairly cheap.
Old 10-28-2009, 06:13 AM
xray99's Avatar
xray99
xray99 is offline
A $3,000 snapon scan tool will tell you far, far more than any handheld OBD2 unit can.
Maybe your talking about something else, but you can get them for way less than $300.
I have one that feeds back basic "live" info, I think I paid $90 for it.
It has it uses, but you are not going to get much serious diagnostic info from it.
I tried searching Whitneys site out of curiosity ,,, I remember getting their catalogs all the time years ago - But my searches kept coming back as "your session has expired", so I couldn't see what they have to offer.
Old 10-28-2009, 06:24 AM
Pysiek's Avatar
Pysiek
Pysiek is offline
Sounds like problem I have before. What the transmission shop told me is to change the catalyc converter,so I did and that fix my problem.
In short my problem was that I can't drive no more then 30-35 MPH and the truck was acting really weird,like something is wrong with transmission. That's why I took it to transmission shop right away.
Quick Reply: Trans band adjustment help?
