2000 5.9L spark knock
Old 10-25-2009, 12:47 PM
okcowgirl97's Avatar
okcowgirl97
okcowgirl97 is offline
Default 2000 5.9L spark knock
Hey y'all, I was wondering if you could help me out a bit. I have spark knock under accleration at about 45-50 mph and maintaining speed between 65-70 mph. I have changed the timing chain and gear, retarded the timing, and replaced the plenum and intake gaskets. Problem still isn't solved. Does anyone have anymore ideas? (And a stick of dynamite isn't an option *L*) Thanks.
Alyssa
Old 10-25-2009, 12:51 PM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
You could try running slightly cooler plugs, or higher octane gas, but that's really more of a band-aid.
I'm sure someone will have something more useful to contribute.
Old 10-25-2009, 12:59 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Could be the deathflash. Is there a hand written sticker on the pcm saying it's been updated? A 2000 might even have it from the factory. A tuner would fix it.
Old 10-25-2009, 01:10 PM
okcowgirl97
Where is the PCM located and I'll go look for that sticker? and what's a deathflash? honestly, it sounds kind of scary...also, forgot that occasionally, it will cause my check engine light to come on (sometimes solid and sometimes blinking) and i've had it scanned and the scanner is not coming up with any codes.
Old 10-25-2009, 01:16 PM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
The stock "death flash" wouldn't cause pinging/spark knock, its designed to prevent it.
How did you retard the timing? Only way to do it on these trucks is with a tuner, you can't manually adjust it like you could on the older vehicles. Turning the distributor or whatever you may have done is bad, causes issues. Undo it.
The stock computer's "death flash" (do a search) retards the timing to far as it is anyway.
After you changed the plenum, did you reset the computer (disconnect the battery, turn on the headlights for a few seconds, turn off the headlights, reconnect the battery)?
Have you checked fuel pressure at the rails? Tested the injectors? Any upgrades to your truck? How long since your last tune-up? (What plugs, wires do you use?)
Old 10-25-2009, 01:19 PM
Cereal Killer
You can retard the timing at the chain, which I'm assuming is what she did since she said she replaced the chain. I don't think that would cause an issue.
Old 10-25-2009, 01:38 PM
Trey318's Avatar
Trey318
Trey318 is offline
If the CEL has come on before, it should be stored on the computer. Have it scanned and see what comes up.
Old 10-25-2009, 01:40 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
the colder plugs that were mentioned are Autolite 3923. they foul faster because they are colder but they are cheap if you get them at walmart. so changing the plugs every 15k won't break the bank.
try running 89 octane first. my dads 98 knocks if he runs 87 but not with 89.
and c4 is much more effective than dynamite.
Old 10-25-2009, 01:44 PM
okcowgirl97
started about a week after plugs were changed (wires havent been changed for awhile and those were whatever autozone carries). champion RC12LC4 (436) plugs were gapped before they were put in. timing was retarded at distributor (dodge dealer mechanic said i could do this, guess he was wrong *sighs*) the rails and injectors have been tested and they all came out as having no problems. the computer was reset after the plenum gasket was changed, changed the thermostat while was in there as well. no upgrades have been made except for the tranny being beefed up a bit for pulling. oil, plugs, and filters were changed about a month ago.
Old 10-25-2009, 01:48 PM
okcowgirl97
It's been scanned since the CEL has come on and nothing comes up. No error codes or anything. Tried running 91 octane, still knocks. Right now, down to considering hijacking the pcm out of a 98 that I have sitting in the yard with a bad tranny but really, really dont want to do that because im afraid it will cause even more issues.
Quick Reply: 2000 5.9L spark knock
