Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
Fuse for headlights on 2009 Dodge Ram
Old 10-25-2009, 11:57 AM
plurr4all's Avatar
plurr4all
plurr4all is offline
Default Fuse for headlights on 2009 Dodge Ram
Where would the fuse for the headlights be located, I cannot find the fuse in the fusebox which is under the hood on the driver side. I was installing HID lights and I believe I blew a fuse on the driver side headlight. Low and high beam does not work but the passenger side low and high beam works just fine. Bear in mind I uninstalled the HID's when I encountered this issue. I simply have no power to the driver side halogen headlight.
PS - This is a two headlight system, not a four.
Old 10-25-2009, 02:06 PM
plurr4all's Avatar
plurr4all
Im starting to think that I fried a circuit on the central computer.
Old 07-19-2010, 07:09 PM
bls8195's Avatar
bls8195
bls8195 is offline
did you ever figure out which fuse number are actually for the headlights?
Quick Reply: Fuse for headlights on 2009 Dodge Ram
