Trouble code P0340
RE: Trouble code P0340
Check this site
http://www.xtremeneons.com/how-tos/c...necodes2k.html
it says your issue is P0340 - NO CAM SIGNAL AT PCM
The car will start and run without the cam signal, but it will run in "limp-home" mode and batch-fire fuel injection - like crap, in other words.
First step, make sure the sensor is actually plugged in. It's on the driver's side of the head, looks like a square with a raised circle. Also check the wiring from it back to the computer and make sure it isn't shorting out somewhere. Replacing the sensor only takes those 4 bolts and a few rags for oil. Don't know how much the part runs, maybe $30-50 depending on where you shop.
Best of luck!
Best of luck!
