Neon SRT-4 Dodge Neon SRT-4 is the pocket rocket that took the import scene and turned it upside down.
downshifting problem
Old 10-22-2009, 10:51 AM
silverbullet09's Avatar
silverbullet09
silverbullet09 is offline
Angry downshifting problem
hey peeps its been a while since iv been on. so i have an 03 model n when i go to down shift into second gear it doesnt seem to want to go in. sometimes i really have to pull on it or i have to slow down ALOT for it to go into gear. i recently changed the tranny fluid & it has helped a little but it still remains a problem. any ideas wat else it could be? thanx!
Old 11-01-2009, 05:57 PM
srt4bad's Avatar
srt4bad
srt4bad is offline
syncro or shift fork my guess
Old 11-03-2009, 03:40 PM
Jims04srt's Avatar
Jims04srt
Jims04srt is offline
Sounds about right. 2-3 and 3-2 are notoriously bad in the SRT-4s. Have you tried rev matching to help? Blipping the throttle when going into second has helped me a lot.
Old 11-05-2009, 09:09 AM
silverbullet09
yeah someone advised me to do that & it has worked. anyone know where i can shop for gear synchronizers or am i just going to have to let the shop take care of that?
Old 11-07-2009, 12:39 AM
Ghost57's Avatar
Ghost57
Ghost57 is offline
good thing i read this post and know that it is a ongoing problem with srt 4's because i noticed its hard from 2-3 or 3-2 as well phew i thought i'd have to get work done on the gears
Old 12-09-2009, 07:42 PM
mldsrt4's Avatar
mldsrt4
mldsrt4 is offline
im gonna start by telling you STAY AWAY FROM AAMCO
i was referred to them for the same problem on my srt 4.....well lets put it this way i rebuilt my whole tranny (fork, synchros, blocking rings etc) and put a atc clutch and flywheel....and 4 months later aamco says thats not the problem it is a "stretched shifter cable" well aamco let me leave free of charge but not willing to attempt the cable becasue i called corprate ans they where sick of throwing money at it without pay....so make sure everything from you shifter to your tranny is ok first so u can avoid my senerio....good luck
Quick Reply: downshifting problem
