5.9 timing chain life?
Old 10-17-2009, 11:25 AM
dnfd737's Avatar
dnfd737
dnfd737 is offline
Default 5.9 timing chain life?
I know on the old la motors about 100k miles is a very good time to change one seems like I jumped timing on several between 101 and 110 k anck in the 80's. I have a 99 5.9 with 95k when should I think about tearing the motor down and doing timing chain?
Old 10-17-2009, 11:40 AM
dakotas ram's Avatar
dakotas ram
dakotas ram is offline
yeah, ive heard 100k and theyve got some good slack in em
Old 10-17-2009, 11:44 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
i changed mine while doing water pump at about 125K. it was pretty worn out and had a lot of slack.
Old 10-17-2009, 12:30 PM
dnfd737's Avatar
dnfd737
dnfd737 is offline
Are there any mods to do while I have everything torn down?
Old 10-17-2009, 12:42 PM
dhvaughan's Avatar
dhvaughan
some people choose to advance or retard the crank sprocket 4*. i didn't feel like i understood that, and i knew i didn't want to tear it back down if it didn't work out right.
you'll want to replace front seal and water pump and water pump bypass hose. check for leaks on rear seal, if its leaking you might want to do it and oil pan gasket.
you sig says you've already fixed the plenum, so no need to tear into the top.
Old 10-17-2009, 12:48 PM
halfamil's Avatar
halfamil
halfamil is offline
Mine still has the original.
Old 10-17-2009, 01:05 PM
aim4squirrels's Avatar
aim4squirrels
aim4squirrels is offline
Mine was a slack as vaughan's was at 60k. It's overdo.
I think my Cloyes HD chain is loose with another 35K on it. The fuel sync wobbles about +/-4* on the snap on scanner. I researched a better chain with some guys who really beat on their engines, and they recommended a JP performance chain. It's sitting in the garage ready to be installed when I order my new cam.
Old 10-17-2009, 04:17 PM
95RAM360's Avatar
95RAM360
95RAM360 is offline
i got 193K and mines the original chain. motor runs mint
Quick Reply: 5.9 timing chain life?
