1999 Dodge Ram 3500 318 V8 Roadtrek
Old 10-01-2009, 03:00 PM
davedawe's Avatar
davedawe
davedawe is offline
Default 1999 Dodge Ram 3500 318 V8 Roadtrek
Hello
Week ago returned on trip of 3000 plus miles,tried starting today,turn over,fast,fuel pump sound,wouldn't start. No start problems on trip
Replaced rotor and cap, cap wouldn't line up with screw downs,one plug wire seems short,
removed plug wires one by one from old to new cap, now wondering if I messed up doing this?
Anyone have a diagram showing plug wires to cap connections?
Appreciate your help
Old 10-01-2009, 04:54 PM
22dodge's Avatar
22dodge
22dodge is offline
any chilton manual will have that. do an internet search for firing order on your van.
but if it suddenly just didn't want to start w/o any warning, why did you replace cap and wires?
do you have spark?
If you have spark and you have fuel, it should run. if not, then you need to look at injector firing and things along that line.
Here's a funny thing I've encountered a bunch of times. vehicle quit running or wouldn't start. had fuel, had spark at the coil but no spark at the plugs. Question is why? I know the answer. it was an easy fix.
Old 10-02-2009, 07:07 AM
shelbydaytona's Avatar
shelbydaytona
shelbydaytona is offline
On my shelby, i had the rotor short in the dist. the spark jumped thru the rotor to the shaft so no start had spark at the plugs but at the coil i seen this show up on a acouple other cars since i found theprob with mine is this the right answer?
Old 09-01-2011, 09:19 AM
Sack.1's Avatar
Sack.1
Sack.1 is offline
Here's a funny thing I've encountered a bunch of times. vehicle quit running or wouldn't start. had fuel, had spark at the coil but no spark at the plugs. Question is why? I know the answer. it was an easy fix. And the answer is????
Old 09-01-2011, 11:36 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Did you register and post this just to annoy us, or you plan to contribute?
Old 09-02-2011, 12:05 AM
stev's Avatar
stev
stev is offline
The answer is ....
TSB 18-48-98
Ignition System Cross Fire/Secondary Ignition Wire Induction
(Complete Version
http://dodgeram.info/tsb/1998/18-48-98/18-48-98.htm
Quick Reply: 1999 Dodge Ram 3500 318 V8 Roadtrek
