Where is Bank 1 sensor 1 on 2000 Dodge dakota
Old 09-26-2009, 01:21 PM
BruinDakotaOwner's Avatar
BruinDakotaOwner
BruinDakotaOwner is offline
Default Where is Bank 1 sensor 1 on 2000 Dodge dakota
HI,
I'm trying to find bank 1 sensor 1 (O2 sensor) on a 2000 Dodge dakota, 4.9L engine
Is Bank 1 driver or passenger side?
Please advise were to find the O2 sensor. I thought I spotted it behind the driver wheel, but I don't want to remove the incorrect part.
many thanks
John
Old 09-26-2009, 01:43 PM
00DakR/T's Avatar
00DakR/T
00DakR/T is offline
I dunno if that is a 4.7 or a 5.9 haha. Either way, bank 1 sensor 1 is the o2 sensor you will see through the driver's side fenderwell.
Old 09-26-2009, 02:06 PM
BruinDakotaOwner
Default I have a $WD quadcab -- could it be north of cat converter?
I checked the items that I can see through the fender well. they appear to be ground straps. One item looks like it screws in to the block. -- to far away from the exhaust manifold
I did find a wired sensor just before the catalytic convertor and another just after the catalytic converter. It was more or on the "exhaust pipe" than the cast-iron exhaust manifold. Could this be the O2 sensor
Old 09-26-2009, 02:26 PM
00DakR/T's Avatar
00DakR/T
00DakR/T is offline
Yeah. The only things that will be mounted in the exhaust pipe itself will be the o2's. Sensor one is the sensor before the converter, sensor two is post-converter. The Bank refers to the side of the engine, bank one is the side of the engine where the #1 cylinder is, bank two is the bank where cylinder #2 is located.
Quick Reply: Where is Bank 1 sensor 1 on 2000 Dodge dakota
