1994 dakota 3.9 fan clutch
Old 09-25-2009, 09:47 AM
csl1260's Avatar
csl1260
csl1260 is offline
Default 1994 dakota 3.9 fan clutch
Need help removing this fan clutch. It is very frustrating.
Any Ideas?
Old 09-25-2009, 11:58 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Crazy4x4RT is offline
Ya that fan clutch can be PIA to get off.
A few tips.
The nut is regular (right hand) thread.
NOT reversed (left hand) thread.
36mm wrench or large crescent wrench.
Use plenty of penetrating oil.
You can keep the belt on to help hold the water pump pulley down.
You can crank down on the belt tensioner bolt to help hold the pulley some more.
There is a tool you can buy to hold the pulley down with called a spanner wrench. http://www.napaonline.com/Catalog/Ca...157_0009852042
Here is a list of suggestions from other members. This will be posted in the FAQ.
Use a strap wrench to hold the pulley. http://www.sears.com/shc/s/p_10153_1...=Y&origin=prod
Use an air chisel to hit the nut on the corner. I could see it damaging it but if it is a last resort.
Put 2 bolts in 2 of the holes in the pulley and wedged a large flat head screwdriver between them to hold the pulley.
Put a large adjustable wrench on it and hit it with a hammer.
Or build your own spanner wrench
Or use a
wrench attachment for your air hammer. wrench attachment for your air hammer.
Lisle LI43300 Pneumatic Fan Clutch Wrench
You won't need to hold anything and it will come right off. Once you use this tool, you'll wonder how you ever got by without it.
Old 09-25-2009, 12:15 PM
pashadowops's Avatar
pashadowops
pashadowops is offline
Penetrating oil is Key like Crazy4x4 says. What I have found very useful for holding the pulley in place believe it or not is one of those Craftsman strap wrenches. http://www.sears.com/shc/s/p_10153_1...d=strap+wrench
I take the serpentine belt off and use the strap wrench in the opposing direction that I turn the nut on the fan clutch.
Old 09-25-2009, 01:49 PM
95_318SLT's Avatar
95_318SLT
95_318SLT is offline
Just to add one more idea to the list... when I took mine off, I put 2 bolts in 2 of the holes in the pulley (they aren't threaded, I just slid them it) and wedged a large flat head screwdriver between them and pressed the screwdriver and wrench together.
Old 09-25-2009, 03:34 PM
festerw's Avatar
festerw
festerw is offline
I usually put a large adjustable wrench on it and hit it with a hammer.
Old 09-25-2009, 03:35 PM
95_318SLT's Avatar
95_318SLT
Lol, but how do you keep the water pump pulley still?
Old 09-25-2009, 04:58 PM
dbilik's Avatar
dbilik
dbilik is offline
I second this idea (kind of ). I took a long piece of flat 1" X 1/4" steel stock. Drilled two holes in it at the same center-to-center spacing as the ones in the pulley. I put bolts in those and held them in with a couple nuts and insert those into the pull holes so I had something to hold onto. Then I took a big wrench and spun it off.
One tip on the penetrating oil, if you are going to use the belt or a strap to hold the pulley, don't get any on the pulley surface. I did that the first time and couldn't hold the pulley for anything.
Old 09-25-2009, 05:05 PM
95_318SLT's Avatar
95_318SLT
Lol, yeah, mine is the cheap and lazy version of your way. Your way is definately better cause I came out with a few busted knuckles.
Old 09-25-2009, 05:38 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A few others have used a air chisel to hit the nut on the corner. I could see it damaging it but if it is a last resort.
Old 09-25-2009, 06:23 PM
festerw's Avatar
festerw
festerw is offline
Leave the belt on, if necessary pull the tensioner against the belt. It's worked 3 times now believe it or not lol, got the idea from another forum.
Quick Reply: 1994 dakota 3.9 fan clutch
