Help! Changed Battery now it won't start!!
Old 09-23-2009, 05:02 PM
thorze's Avatar
thorze
thorze is offline
Default Help! Changed Battery now it won't start!!
98 Durango 5.2L 190,400 miles and YES there is gas in it... LOL!
Okay Battery was dead after sitting two days, got charger out and hit with a 100 amp start and would'nt start. So I left it to charge. Checked back on it and Battery would not take a charge, so I went and got a new one and engine cranks but won't start.
After attempting to start I left the key on, the low fuel light came on and the odometer began blinking??
Also the security light is illuminating even afetr I hit the unlock button
Checked for pressure at the fuel rail and occasional it will shoot out and othertimes it will dribble, I do not hear the pump fire up although the fuel gauge comes up, but not to where it should be??
Relays and fuses in PDC checked and work
Any Ideas would be greatly appreciated..Thanks
Carl
Old 09-23-2009, 05:28 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
sounds to me like your fuel pump is shot, the gas gauge is built into the same unit so drop that tank and replace it, especially if it has never been done beofre 190k is ALOT more than the pumps are expected to last for
Old 09-23-2009, 05:53 PM
thorze's Avatar
thorze
thorze is offline
Thanks for the reply
so you don't think it something else, as I had no issues at all before I changed the battery??
Old 09-24-2009, 02:24 PM
Kensai's Avatar
Kensai
Kensai is offline
there is a huge 100 amp fuse in teh fuse block under the hood, check to make sure it is not blown.
Old 09-24-2009, 05:15 PM
thorze's Avatar
thorze
thorze is offline
I checked and it and the only one I found that big was a 140 amp fuse for Alternator, which checks Okay.
Bought the 54.94 pump off Ebay, which is just the pump and not the module, I will check back in with the results....
Thanks for the wisdom guys!
Old 09-25-2009, 12:01 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Rain fuel psi should be 50 or better.
Sounds like a bad pump and a bad battery.
Old 09-26-2009, 01:16 AM
jj141979's Avatar
jj141979
jj141979 is offline
Thorze. I have a similar problem with mine. I had the battery die before and MAN I thought CHRISTINE some how posest the Durango!LOL!! The lights were going off and on. Every relay was clicking, the gauges were freaking out!!!! Well got a new battery hooked up, turned key over and all it would do is turn over, no fire! Put key back to off and tried again, it fired right up. Everytime I disconnect the battery for some reason, I always have turn the key to start for a few secounds and than back to off, then to start again and it fires right up. HOPE THIS HELPS!!!
Old 09-26-2009, 02:43 AM
Nofrag's Avatar
Nofrag
Nofrag is offline
There's a reason the security light is blinking. It's because the anti-theft is disabling your durango. What the guy above is talking about, is resetting the anti-theft.
Old 10-06-2009, 10:21 AM
thorze's Avatar
thorze
thorze is offline
Okay Guys, I got the Pump off ebay and disassembled the module and reinstalled the new pump**CAUTION** this is not an easy job to do as you must modify a couple of things but is very do-able (PM FOR FURTHER INSTRUCTIONS)
I just put the tank in and lifted it enough to check it before I finish the install, cranked on it and nothing, no pressure at the fuel rail and I can not hear the pump pressurize at all.
Could it be the crank position sensor, as I have rechecked all of the relays and they are good.
Any Wisdom would greatly be appreciated!!
Old 10-06-2009, 11:51 PM
hydrashocker
You disassembled the module??????? What module and how?
Drop the tank again and check for voltage.
Quick Reply: Help! Changed Battery now it won't start!!
