92 Ram 350 Fuse Diagram?
Old 09-11-2009, 10:32 AM
Jtreign9097's Avatar
Jtreign9097
Jtreign9097 is offline
Unhappy 92 Ram 350 Fuse Diagram?
Not Sure if anyone here can help me
i have a 1992 Dodge Ram 350 CNG 5.2L
I need to know what fuse does what in order to jump out some
things. fuse box is in the glove compartment with no labels or anything.
Old 09-11-2009, 10:58 AM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
I found one for a 1990 B250 van. I'm fairly positive it's the same.
Old 09-11-2009, 12:03 PM
Jtreign9097
Thanx alot i think this will help me out.
i not even sure if the cng version is the same as the regular ones but this should help me out with the numbers under the fuse if its listed. thanx alot man
Old 09-12-2009, 11:41 PM
Jtreign9097
Nah this fuse diagram was not the one i have. mine is a giant rectangle block with space for at least 20 fuses tops. unless theres another fuse box that may help me but this giant inside the glove compartment must be it... i have no brake lights,headlights,reverse lights, reverse siren,park lights,tail lights but my signal lights work perfect.. and all fuses are good! witch why im going crazy here.
Old 09-13-2009, 02:58 AM
alloro's Avatar
alloro
alloro is offline
Have you checked for burnt fusible links?
Old 09-13-2009, 03:36 PM
Jtreign9097
yea fuses are good but i found some wire schematics that should help me fix this issue. i will trace out all the hot leads that power the fuse block. the culprit is probably a bad hot lead. there's about 4 large hot lines that power each row of fuses. when i hit a live 12+ line against one of the other dead lines it shorts. im an eletrician and htis is driving me nuts..lol only due to the wire harness all sealed up i can't see were every wire goes. but i will try what the factory schematics say.
Old 09-13-2009, 05:52 PM
alloro's Avatar
alloro
alloro is offline
Originally Posted by Jtreign9097
yea fuses are good
Not the fuses, the fusible links. They're located up around the brake booster. Here is some information on them:
Old 09-13-2009, 06:02 PM
alloro's Avatar
alloro
alloro is offline
I'm an electrician
Same here, at least I know now that I don't have to dance around the lingo with you.
Old 09-14-2009, 05:03 PM
Jtreign9097
Thanx man i had no idea there were fusible links before there probably shorted but i did jump out most of it but i guess i can re-use the original stuff if i find this its all sealed up in wire harness's i bet
Old 10-30-2009, 05:55 AM
Jupiler's Avatar
Jupiler
Jupiler is offline
Hi everybody,
I just bought a 1992 b350 van, 5.2 V8.
I live in Belgium, Europe, so nobody can help me here to find a fuse diagram.
Did you find one ? I'm very interrested in getting it.... Thanks !
Quick Reply: 92 Ram 350 Fuse Diagram?
