rack and pinion installation
Regardless of who does it(you or a garage) an alignment is needed afterwards because the rack is bolted to the Tie-rod ends that control the steering. The Toe angles are going to be comprimised once you change the rack or remove the tie-rod ends. There is no way around it. Gonna cost you $70+/-.
The hardest part is draining the reservoir and un bolting the lines that are crammed together and hard to access. Other than that, there is the steering shaft bolt(mark the steering shaft on both sides before removal. The rack is held on by 2 bolts.(not sure how hard those are to remove or what would be in the way for them to be pulled all the way out as they are long.
For the new one, you need to find the center of the steering. Measuring each side is the easiest before you bolt it up in there. Then you align the shaft on the rack to the stering shaft(keep the steering shaft as it was and moved the rack gear to align to the steeering shaft so your steering wheel remains straight.
For the tie-rods. i would just buy and install new outer ones. The rack should have new inner ones already????Hopefully.
As for bolting the teirods correctly, best you can do is measure a specific spot off the case to the center of the balljoint case on the outer tie-rod. then this will allow you to measure off the same point on the new case for the new tie-rod. Then you will be able to drive to an alignment shop without much hassle. If the toe is way off, you will bind pretty bad around turns. Not good for the rack.
There is a bleen screw on the bottom I belive but it will take a while for all the fluid to drain out. (like overnight) just incase you thought it was the best way...lol Messy is the quickest way!
on
dirtydog makes it sound harder than it is. if you have some basic tools, a jack, and some jackstands you can easily do it yourself. the hardest part for me was getting the tie rod ends out (theyre pressed in) make sure you put new ones on while youre at it. the big *** bolts come out of the rack pretty easily. the lines arent that hard to get at if you have the truck jacked up a little. and as far as getting things lined up, just make sure the steering wheel is straight when you pull things apart, and count the number of threads sticking out on the tie rod ends. then when you put it back together just count up the threads and you will be pretty close. i did mine in the driveway (parents werent too happy about the mess). just pull the lines and let it drain.
take it from someone who has actually done it... piece of cake.
shop quoted me at almost $500, i did it for about $200
**make sure you use atf+4 for the fluid
got anymore questions let me know
^^^ Not everyone is mechanically inclined to think the rack is an "easy" task. and your "piece of cake" task takes the average guy about 3-4hours in the driveway with proper tools.
Also, how did i make things sound complicated? I was just being precise on the tie-rod measurements because counting threads when you change racks or tie-rods is not the way to go about things as each manufacturer is diff.
He should have new tie-rods installed with the new rack. Or else, he may have to get them replaced and then get anotyher alignment shortly down the road.
on
^^i thought you might get a little wound up about my post (you can be a testy bugger)
but it really isnt that hard. before i did mine everyone was telling me it was a PITA (some on here) but i didnt want to dish out the $$ so I figured what the hell, i'll give it a try. It did take me 4+ hours to do, but I was taking my time.
and my rack (long rack) came with everything but the tie rod ends, so i got new ones which is recommended especially if you remove them with a sledge hammer like i did
i guess you didnt make it sound that hard, but the poor guy seemed overwhelmed... wait till he reads all this crap! haha
