2001 dodge caravan sport tcm loctation ??
Old 09-03-2009, 12:43 AM
GBAL4's Avatar
GBAL4
GBAL4 is offline
Default 2001 dodge caravan sport tcm loctation ??
Got a code scanner and got the code P0605 and now my transmission will not shift out of second gear. I think I can replace this my self I just need help in locating the TCM. I can send mine out for a rebuild for 125 or call a salvage yard for a used 1 for $ 100 .
thanks for the help
Old 09-03-2009, 10:16 AM
per4manz's Avatar
per4manz
per4manz is offline
The TCM is located behind the splash shield of the front left wheel well.
Old 09-03-2009, 03:51 PM
GBAL4's Avatar
GBAL4
GBAL4 is offline
okay I thought I had located the TCM I had found a large box in front of the battery with 2 huge plugs in it then after reading the box itself it was not the TCM and going back to the last post I was looking in the wrong location. BTW what is this box infront of the battery it saying something about and software update in 2002 ?? I`ll put everything back together and go to the passenger side for the TCM do I have to get a jack and lift up this side to get to the TCM ??? thanks everyone for the help !!!!
Old 09-03-2009, 05:38 PM
GBAL4's Avatar
GBAL4
GBAL4 is offline
okay guys for some reason I can`t locate the TCM is it behind the passenger front tire or in front of it do I need to jack the van up to find it ??
Old 09-07-2009, 02:01 PM
GBAL4's Avatar
GBAL4
GBAL4 is offline
okay I have removed what looks like a black box with a very long connector. The connector has a long screw in the middle of it .There is a bar code on it but it does not say if this is the TCM module. Please help let me know if I have found the right part ...............thanks for the help Gabe
Old 09-07-2009, 07:56 PM
GBAL4's Avatar
GBAL4
GBAL4 is offline
Anybody ???
Old 10-14-2009, 05:03 PM
jdbengst's Avatar
jdbengst
jdbengst is offline
Default TCM Problem.
Did you ever get your TCM found and resolved?
Old 10-15-2009, 10:32 AM
vabear's Avatar
vabear
vabear is offline
On my '96 the TCM is bolted to the right side fender, (passenger side) and is right in your face as you open the hood.
Old 10-16-2009, 12:34 PM
GBAL4's Avatar
GBAL4
GBAL4 is offline
Yes Tcm was found and I called a salvage yard got another TCM from another caravan mounted it back up and WALAH it works perfect no check engine light and everything is fine !!!!
Old 10-19-2009, 10:07 PM
jdbengst's Avatar
jdbengst
jdbengst is offline
Default TCM issue
Glad you got it taken care of - it seemed you were having trouble finding it. As I suspected, my problem was the solenoid pack, but I had to pay the dealer $80 to do a diagnostic to confirm it. He wanted another $450 to replace, so I'll be doing it in my own garage.
Quick Reply: 2001 dodge caravan sport tcm loctation ??
