Governor pressure sensor
Old 08-27-2009, 02:36 PM
hirschy's Avatar
hirschy
hirschy is offline
Default Governor pressure sensor
I got a code the other day it was code 45 - Governor pressure sensor volts too low. would this code cause the truck to drive like a damn brick?( mashing the gas and not doing anything) from a stop light it sounds like it really has to work to get to normal driving speed.
Is this the problem or is it something more?
Roughly how much would it cost for parts to do it myself? or is it one of the things a shop should look at?
Thanks,
Jeff
Old 08-27-2009, 03:43 PM
helms's Avatar
helms
helms is offline
sometimes this will cause the transmission to stay in 2nd gear when stopped, so when you accelerate, it feels like the truck is really struggling. try not to push it too hard when this happens or you will have a transmission overhaul bill on top of your current problems.
Try doing a search for Governor pressure sensor, it is a VERY common problem.
Old 08-27-2009, 11:28 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Ram15002ndGen is offline
Nah, it's not hard to do at all. Look in the DIY section, I think Xray put up a DIY replacing all that and it was cheap. If you truck is giving you trouble shifting, try going into manual and see if that helps. That's not a solution, but it will get you home so you can get this fixed.
Old 08-28-2009, 12:53 AM
hirschy's Avatar
hirschy
hirschy is offline
thanks I'll take a look in the diy section
Old 08-28-2009, 02:16 AM
xray99's Avatar
xray99
xray99 is offline
Don't think it ever made it to DIY, here it is
https://dodgeforum.com/forum/2nd-gen...d-install.html
Should probably consider replacing both sensors while your in there ,,, And possibly installing a drain plug as well.
Replace with a new filter and quality ATF +4, hopefully that will cure the problem.
Old 08-28-2009, 02:38 AM
hirschy's Avatar
hirschy
hirschy is offline
thanks xray99 i have to look at that.
Quick Reply: Governor pressure sensor
