2nd Gen Durango 2004 - 2009
Dodge Durango 2007 5.7HEMI Gas cap signal
Old 08-17-2009, 12:14 PM
vzenit's Avatar
vzenit
vzenit is offline
Question Dodge Durango 2007 5.7HEMI Gas cap signal
Hello! Do you know how can I reset computer to shut down gas cap signal? Mechanics use the PDA sanc the truck and No signal of failures appears, but gas cap signal is still sparkling! When We start the machine and push the button at the front disappears but again when start the truck again appears.
Old 08-17-2009, 02:11 PM
1969CoronetR/T's Avatar
1969CoronetR/T
1969CoronetR/T is offline
vaffanculo
It may be a bad oxygen sensor that is tripping the gas cap alarm,
FF
Old 08-18-2009, 06:23 PM
vzenit's Avatar
vzenit
vzenit is offline
do you know how to change the oxygen sensor? its easy to change? its is cheaper or expensive?
many tanks for your help!
Old 08-18-2009, 07:20 PM
1969CoronetR/T
vaffanculo
I never changed one because both times that one failed (on a Honda) it was under warranty. http://www.popularmechanics.com/auto...o/4219927.html
This link may help,
FF
Old 06-23-2011, 01:27 AM
Sblunden's Avatar
Sblunden
Sblunden is offline
Default Gas cap signal and check engine light
I just had this same issue on my 2007 limited. I replaced the gas cap with a new one but the warning signal and check engine light still kept coming on. A mechanic friend then suggested disconnecting the negative on the battery for 5 mins. Did this and it's all fixed. No check engine light and no gas cap warning signal. Better yet, no big bill from the stealership
Old 06-23-2011, 02:31 PM
jamesjessup's Avatar
jamesjessup
jamesjessup is offline
I have a 2007 Dodge Durango, 5.7 Hemi. I am having the same gas cap issues, that I have reset several times. I also tried the negative terminal disconnect. The issue of the gas cap and engine light still persist. I have taken it to the dealer twice and they cant fix it either. I had installed a cool air intake and cut out the catalytic converters and installed a straight pipe a while back. I assumed that may be part of the problem, but obviously not. I have read about this same complaint before on other sites. Is this a recall item that Dodge has put out? How do you fix this? I moved to Dallas, Tx from Phoenix and cant get my truck registered until this is fixed.
Old 06-25-2011, 10:21 AM
Sblunden's Avatar
Sblunden
Sblunden is offline
Update - The negative terminal disconnect got rid of the gas cap warning and check engine light for a couple of days but now just the check engine light is coming on. Problem still not solved any ideas before I give up and send to the dealership? We have a big trip planned towing our trailer and I don't want to take the risk of doing this with the check engine light still on. Should I be worried?
Old 06-25-2011, 05:31 PM
sydmoe's Avatar
sydmoe
sydmoe is offline
Have had same problem. I changed the cap and reset by disconnecting the batt. Problem came back. I blew air in the vent by the gas filler tube inside the fender well, reset and that lasted 3 weeks but then check engine and gas cap message once again returned.
Quick Reply: Dodge Durango 2007 5.7HEMI Gas cap signal
