steering wheels shakes....
Old 08-12-2009, 07:15 PM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
Default steering wheels shakes....
i searched and everything takes me to death wobble i dont think i have death wobble but i do experience a steering shake when i hit my brakes at 45-60 and its just worrying me i have new tires the pressure might be off a tad pads are good on brakes about 3/8 left ...im not sure what it is and it just feels like the front end is shimming or loose maybe but i know everything is tight i havent worked on anything on the front steering any ideas i know you guys should thanks in advance.......
Old 08-12-2009, 07:45 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
When you HIT your BRAKES and get any type of Vibration or Wobble.....This means your rotors are warped!
Death wobble as everyone knows it as is simply a wobble at all speeds and gets worse the faster you go. it's very noticeable in 4wd
If your rotors aren't the problem. Worn out tierods can cause steering wobble when brakes are applied as well, but generally people would experience "wander" while on the highway if the tierods are bad.
Old 08-12-2009, 07:49 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Yep, sound like the run-out on the rotors is out of spec. It doesn't take much.
Old 08-12-2009, 09:02 PM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
Stupid double post
Old 08-12-2009, 09:04 PM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
I can let off the brakes and then rebrake it will go away most of the time what are some rotors i should look at dont break me now....
Old 08-12-2009, 09:35 PM
nim81's Avatar
nim81
nim81 is offline
duralast gold......
Old 08-12-2009, 10:06 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Def. your rotors. Powerslot makes a good rotor. AIRRAM has good prices. New rotors and Good pads will run $250 for the front axle. Good pads means NOT semi-metallic. Ceramic, kevlar and other exotic materials are what should be used.
Old 08-13-2009, 10:00 AM
Markmm0000's Avatar
Markmm0000
Markmm0000 is offline
i did breaks and rotors on my truck prob 6 months after i bought it in 05. the stock ones were already warped. i got rotors and pads for 150$ per axle and still ride with the same rotors - no wobble today.
Old 08-13-2009, 10:26 AM
espinosafell's Avatar
espinosafell
espinosafell is offline
I got Duralast Rotors and Ceramic Duralast Cmax Gold Brake Pads all for 154.00 and I brake so peacefully & I have a lot more control over my truck over stock and I had the same shake it would go away and come back when braking... Like Dirty said its the rotors... But when your down there check the tie rods... I dont need performance rotors cause i just commute to work & occasionally haul...
Old 08-14-2009, 10:35 PM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
alright ill start doing some research and looking for parts....any other suggestions
Quick Reply: steering wheels shakes....
