Best plugs for a 2005 4.7
Old 08-09-2009, 10:32 PM
DaHipaKea1313's Avatar
DaHipaKea1313
DaHipaKea1313 is offline
Default Best plugs for a 2005 4.7
From my earlier thread today on my rough running and idling problem I'm going to change out my spark plugs when I do the oil change. What are the best ones to use power and economy wise? And how bad, because I've heard rumors about it being tough to change them all out. Any suggestions will help.
Old 08-11-2009, 03:23 AM
bigmike05ram's Avatar
bigmike05ram
bigmike05ram is offline
they are easy,just start from the far back left to right cause its tight back there... mines run great on autolite triple platinum
Old 08-11-2009, 04:25 AM
Spokane_Dodge's Avatar
Spokane_Dodge
Spokane_Dodge is offline
Everyone I have talked to has said the Champion Coppers for the RAMs. Will be replacing mine with them shortly
Old 08-11-2009, 06:25 AM
BadHab1t's Avatar
BadHab1t
BadHab1t is offline
hands down ngk v-power run in everthing i own used on my last dodge also....2.13 each not just cause of price they run cooler than most plugs i heard that platinum plugs are a waste on our trucks....
Old 08-12-2009, 06:53 AM
DaHipaKea1313
So anyone of these are a good choice then. Thanks guys, H-
Old 09-07-2009, 10:38 AM
Plainbroke's Avatar
Plainbroke
Plainbroke is offline
put in a set of those E3s and let us know how the MPG is I know they fixed the stumble in my ATV..
Old 09-07-2009, 01:14 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Champion Copper core or NGK V-powers are the best choice for sure!!!!
I prefer the V-powers myself. Those gimmick plugs are just that. 3 and 4 ground straps? no need unless you are maybe running 30psi of boost.
Platinum last longer but has a weaker spark. Copper is the best conductor of electricity.
Old 09-07-2009, 01:17 PM
Altair's Avatar
Altair
Altair is offline
Dak attack!
I've had great results with the Autolite 3923's, a lot of other 4.7 dakota guys have as well. Best part is they're very cheap, give them a shot and if you don't like them you've only lost $12-14 and maybe a half hour of time.
Old 09-07-2009, 02:03 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Yes, Autolite is a good plug as well.
Old 09-11-2009, 11:26 AM
mrbrace's Avatar
mrbrace
mrbrace is offline
NGK all the way...good solid plug and have always used them in all my vehicles, never had any issues
Quick Reply: Best plugs for a 2005 4.7
