Old 08-05-2015, 08:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
Help! Ignition switch broke.
Old 08-06-2009, 01:46 PM
That1guy's Avatar
That1guy
That1guy is offline
Default Help! Ignition switch broke.
Yeah so on my ram my ignition is screwing up. The last couple days when I turn off the truck the blower for the AC kick back on and blows air out the vents. The dash switch works fine I can control the speeds and turn it off. So when the truck is in the run position everything is good. Turn the key to off, everything turns off. Turn it the last turn to pull the key out and the blower kick on. I've figured it out if I pull the key out a little and turn the key back towards the acc position then it shut off. It's weird because it's the onlything getting power without the key in it.
So I assume my key switch is broke. Can I fix it? How much would a shop charge? Thanks for the help.
Old 08-06-2009, 02:44 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
PM me to remind me and I will send you the info out of AllData to tell you what all you need to do to do it yourself. Ive dont them in older cars but not a Ram.
Old 08-06-2009, 04:18 PM
reefguy89's Avatar
reefguy89
reefguy89 is offline
it is really easy. All you have to do is take the 3 screws (You can use a alan key)out of the steering column cover. Next if you have tilt steering you need to take the a few screws out of the assembly to move it out of the way. Then disconnect the wire harness plug. Unscrew the ignition switch and pull it out. THen put everything back on. Just follow the same order just backwards. You can get the part a advance autoparts or autozone for like $25 bucks. This is what the plug looks like. Also while there look for burnt wires.
Old 08-06-2009, 05:38 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Well there you have it........Let us know how it works out.
Old 08-07-2009, 02:42 PM
That1guy's Avatar
That1guy
That1guy is offline
Ok sweet it seems pretty easy. What part do I have them look up? Just ask an ignition switch? Will I be able to still use my factory key?
Old 08-07-2009, 03:29 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Go to www.autozone.com and enter your trucks info. I would have done it for you but you dont have listed what year your truck is. From there go to the ignition parts and in there you will find the switch. The older cars replaced the cylinder and all and came with new keys. IDK how the new ones work. You will have to take your out and take it with you to AZ and compare it to the new one to make sure it all matches up.
Old 08-07-2009, 03:34 PM
That1guy's Avatar
That1guy
That1guy is offline
Ok I figured it out. My truck is a 02 BTW.
So napa has a switch for 23 dollars and it appear to only replace the switch itself and not key part. So I think I have it figured out. Thanks everyone.
Old 08-07-2009, 03:50 PM
That1guy's Avatar
That1guy
That1guy is offline
Yeah so advance is completely sold out and has no clue how to get more.
NAPA has one for 23 dollars 45 minutes away.
Called the dealer for fun and theirs was only 29 dollars. So I decided to go with a factory part. Turns out its on major back order, as in 3000 some. They found 26 of them in the dealers system but those who have them wont sell them. Yeah so only 26 of these exsist in the entire united states and according to chrysler they dont plan to ship any soon. Awesome!
Old 08-07-2009, 03:58 PM
reefguy89's Avatar
reefguy89
yea these ignition switches really suck. I would take the 45 min drive to get one cause my company just got one (from autozone) for my work van they where going to get it from the dealer ship but they where on back order. So 45 min to get one is not bad comparred to monthes of waiting. I would call and see if they can hold it.
Old 08-10-2009, 08:08 AM
That1guy's Avatar
That1guy
That1guy is offline
Okay so I got the new switch installed. Took me a few minutes to figure out how the key cylinder poped out. The whole thing was in my haynes book.
I got it in and it turns out the part that was in there was the exact same part from napa. Like the same brand. Even the stickers were a prefect match. I was confused because usually factory parts have chrysler stuff on it.
Anyways it's all fixed and working good now. It was a 10 minute job. Thanks everyone.
Quick Reply: Help! Ignition switch broke.
