map sensor problems?
Old 08-06-2009, 12:42 PM
bullet1118's Avatar
bullet1118
bullet1118 is offline
Default map sensor problems?
Hey all, I'm having map sensor code 0108. van idles very bad tach just jumps up and down and so does the engine. I can't go faster than 45mph. Van lurches forward when stopped at a light and act like it wants to stall. I replace the map sensor twice and replace the tps sensor and still same problem. Funny thing is I can drive the van in auto stick and drive a fast as I want. Also getting black smoke out the exaust. When I put the new map sensor on I reset everything disconneted the battery and everything was fine for a day or two then map code came back. All this happen initially after a gas fill up. 02 caravan 3.8l Getting ready to take it to the dealer before I found this site. Thanks for any help
Old 08-06-2009, 06:05 PM
kev2's Avatar
kev2
kev2 is offline
P0108 (M)
Manifold Absolute Pressure/Barometric Pressure Circuit High Input
MAP sensor input above maximum acceptable voltage
where does it say change ANYTHING? codes do not mean chnge a component....this COULD BE a sensor seeing an out of "range" reading....
low vac = hi voltage.....
>any other codes?
>1st what is ENG vac reading ?
I would look for a vacuum leak. try the old spray trick to locate a leaking area/component.....
Old 08-06-2009, 07:29 PM
rabbler's Avatar
rabbler
rabbler is offline
Look for a broken wire in the MAP harness or bad contact at the connector to the sensor.
Old 08-06-2009, 08:26 PM
kev2's Avatar
kev2
kev2 is offline
PROBE AND post Voltage use a DVOM...
back probe vio/brn wire at map sensor....signal to PCM
back probe org/pnk*....... should be 5v (referance)
* might be pnk/yellow.
Old 08-10-2009, 12:23 PM
bullet1118's Avatar
bullet1118
I tried the spray trick didn't see anything. I have someone looke at it and the pcm is bad he's going to try and get me one. I don't have anything to check the voltage. Codes I'm getting now are 1684 battery code thing, 0123, 108, and 1598
Quick Reply: map sensor problems?
