parking lights and tail lights stay on
Old 08-05-2009, 10:19 PM
paoul's Avatar
paoul
paoul is offline
Default parking lights and tail lights stay on
I have a 2005 ram 1500 4x4 hemi i got home from work today shut truck off and my parking lamp and tail lights stayed on i checked headlight switch it is off so i started the truck and kept turning the switch on and off finally the lights went out till i shut the truck down again they came back on what could the problem be? *update* i start the truck up the lights go out unless i turn the headlight switch on then they function normal turn switch off and turn truck off the lights come back on and either stay on or may stay off for a few mins then come on by themselves and stay on
Old 08-06-2009, 02:40 AM
VP64's Avatar
VP64
VP64 is offline
only one thing can be doing this. these guys-->
your truck sounds like it is haunted
Old 08-06-2009, 06:59 PM
hemiquad4x4's Avatar
hemiquad4x4
hemiquad4x4 is offline
Those are some really long sentences! I got a headache from reading that.
You might have a loose ground somewhere or a faulty switch.
Old 08-07-2009, 01:37 AM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Glitch in the PCM. You might try unhooking the battery for about 1/2 hour and see if it helps any.
Old 12-24-2009, 11:35 AM
Big_Wheel's Avatar
Big_Wheel
Big_Wheel is offline
did this work??? i have the same problem going on with my 04 dodge 1500 Q/C
Old 10-13-2011, 05:08 PM
powrguy's Avatar
powrguy
powrguy is offline
Default Parking lights stay on Ram 1500 2004
I have the same issue. Suddenly, one day the parking lights came on, and will not go off. The switch does nothing, the start the engine, play with the switch, etc. does nothing.
What I did was pull the fuse to turn them off, then put it back in, and pulled the relay to turn them off. Now, when I drive at night, I have the relay laying in the ashtray, and I install it to drive, and remove it when parked.
All connectors to the fuse box were checked and clean. PCM?
Old 10-13-2011, 05:39 PM
SLT8's Avatar
SLT8
SLT8 is offline
Little belated for the OP but i hate dealing with electrical gremlins.
Old 12-05-2014, 05:16 PM
plowjocky21's Avatar
plowjocky21
plowjocky21 is offline
Default Found problem
My truck was doing the same thing. Fuse to trailer light plug #33 pulled and problem stopped. I will repost with fix on plug soon.
Old 12-05-2014, 05:29 PM
plowjocky21
Default Problem sort of resolved
Hi there pulled fuses one by one until i hit #33. It goes to the trailer hitch wiring harness. The lights went out.Parking are all back to normal. I have a snowplow with a control module that switches the lights from truck to plow and back that i replaced but still no luck and replaced the headlight switch too still nothing until i pulled that fuse. My lights were staying on with truck off and headlight switch off but half bright on parking circuit only. if it turned the headlight switch to park they would go full brightness. The headlights through all of this were not affected just parking and top cab Lights.My truck is a 2004 Dodge Ram 4x4 5.7 Hemi 2500HD. Standard cab and bed.
Old 12-06-2014, 05:25 PM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
Sounds like you guys might be having issues with the PDC. Also might want to check the relays in the PDC also, I believe the relays are fired by the PDC, maybe they're getting worn out. Try switching a couple of them around with the ones that are used for the lights.
Quick Reply: parking lights and tail lights stay on
