Old 08-05-2015, 09:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
HID headlights
Old 08-01-2009, 02:59 AM
98cherryram's Avatar
98cherryram
98cherryram is offline
Default HID headlights
Do the headlights in these dodges have the flicker problem that I hear of? will I need to get the flicker relay harness that tricks the computer into thinking that the lights are running 55 watts instead of 35 watts? I didnt get it for the fog lights because I am almost certain they dont need it right?
oh, and also, does anyone know how what to do with the daytime running lights when running hid's? because I hear they cause problems.
Old 08-01-2009, 04:13 AM
CNFD's Avatar
CNFD
CNFD is offline
I just got done installing my new kit.
My origional had a bad flickering problem so I ditched it and got a new one. I know people here have rigged theirs to work (relays, extra sockets, etc) but I'm not too good with wiring (haven't had too much expereince with it) so I just got a whole new kit that I knew would work. As for the fogs, the computer won't have a problem with them, hence no flickering.
Not sure about DRLs, but last time i checked only those in canada had them. mine doesn't, so not exactly sure. hope this helps!
Old 08-01-2009, 04:45 AM
hontzy87's Avatar
hontzy87
hontzy87 is offline
If you get a kit, go to HID's by twiggy. He IS the man. All the flicker problems and DRL probs will be taken care of. The fogs you and run without a relay harness, they won't give you issues. The headlights depending on which year dodge ram you have you might have flicker. My 03' doesn't have DRL and i didn't need a relay or anything, but i got my kit from twiggy anyways cause he's warranty's everything. If you search also, you will find ALOT of **** on this topic, it's been covered a million times so that might help instead of having to wait for people to respond
Hontz
Old 08-01-2009, 09:25 AM
SilverBullet08's Avatar
SilverBullet08
SilverBullet08 is offline
i got some from the vendor on here. all plug and play. oh and they are more than half the price of twiggys
Old 08-01-2009, 10:09 AM
bigmiah22's Avatar
bigmiah22
bigmiah22 is offline
I had problems with my 03 but i just bought a cancellor and it took care of my problem.
Old 08-02-2009, 04:18 AM
CNFD's Avatar
CNFD
CNFD is offline
my new kit is from twiggy. I have to say, its high quality. I rather spend the extra 100 bucks to get headlights that I know will work, because driving at night with no streetlights and flickering headlights is just an accident waiting to happen. the extra 100 bucks gives me peace of mind.
Old 08-02-2009, 05:15 AM
hemipower05's Avatar
hemipower05
hemipower05 is offline
i have an 05 i had to do the same thing.... i think the company i got mine from called the stupid lil thing a "warning code eliminator" i was told to get the relay harness and after hookin it up, it didnt work... and that guy had an 06-08 model ram.... im startn to think that 02-05 need some sort of code eliminator and the 06-08s need the relay harness.... just a thot
Old 08-02-2009, 12:30 PM
SilverBullet08
yea our vendor said that i that the 05 dont need the relay harness. we just need the capacitors that are supposed to eliminate lamp out. but thats not working on mine for some reason
Old 08-02-2009, 01:18 PM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
I have them on mine and never had any flicker or lights out issues. I got mine from Chad at Unique Coatings.
Old 08-03-2009, 04:51 PM
98cherryram
My truck is from canada originally, so it has the DRL's, and I have the truck with the laramie package, so I have the computer that does like everything, so I would imagine mine has that feature that tells me if a light is out, I guess I could always just unplug one and check haha, that would probably tell me
Quick Reply: HID headlights
