Help Drive shaft support bearing
Old 07-28-2009, 01:16 PM
hondarider's Avatar
hondarider
hondarider is offline
Default Help Drive shaft support bearing
My support bearing the is under the pickup bed blew out today. It connects the two shafts into one. Does anyone know how to replace this?
Thanks
Old 07-28-2009, 01:32 PM
pavement_hater's Avatar
pavement_hater
pavement_hater is offline
Take the drive shaft out. Once its out, most likely the center bearing won't just slide off so you may have to hammer the **** out of it. Maybe even use a little heat. I never changed one in a pickup but have done them in a big rig. I figure it should pretty much be the same concept.
Old 07-28-2009, 01:38 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Remove the rear shaft first. Then remove the front half including the carrier as one piece. take it a machine shop (unless you have the right tools) and have them remove and press a new bearing on.
Old 07-28-2009, 03:00 PM
hondarider's Avatar
hondarider
I bought the bearing with the support and it looks like you just slide it on.. but i do have to pull the shaft. ok thanks. if there is anything else, let me know
thanks
Old 07-28-2009, 03:07 PM
zman17's Avatar
zman17
zman17 is offline
I don't have one of those, but IIRC, it does look as though it slides on and off, but that is not the case and it does need to pressed or the use a a BFH. lol
Old 10-14-2011, 08:18 PM
tomdel45's Avatar
tomdel45
tomdel45 is offline
how do i remove the center bearing from a 1997 dodge ram 4x4 pick up? i droppen the drive shaft but can not get the center bearing off of shaft.
Old 10-14-2011, 08:26 PM
zman17's Avatar
zman17
zman17 is offline
Quick Reply: Help Drive shaft support bearing
