How much weight will 1500 rear axle take ?
I use my 06 1500 for everything, daily driver, hardcore off road,firewood hauler, sled hauler ..etc etc....
My question is, How much weight will these rear diffs take ?
I have seen how small these axles and bearings are [at the dealership], mine seems incredibly strong, I abuse the hell out of this truck, and she keeps on going with not a single failure, but, since my 3/4 ton has give up the ghost I will be using my half ton as my full time sled hauler, sled deck = 350 lbs + 2 sleds =1200 lbs= 1550 lbs payload. I'm thinking of adding air helper springs to stop sag, but, how much will these diffs really take ?
Liability isn't a problem around here ! I don't live in a populated area, and my truck spends 90% of its life in the bush on logging roads. but, thats my point, I'm not driving up and down the highway , I'm on rough, rutted, muddy , snow covered bush roads turning big rubber. And I don't have the option of pulling a sled trailer because of the terrain, but, thanks for the responses, I guess I'll just keep beating on her until I find the breaking point !!!
I haven't cracked the differential, but since it's a half ton I'll assume that if you overload the truck too much the first failure mode will most likely be the axle popping a c-clip. Allowing the axle to slide out of the differential (not good) cornering with a load will cause it. Or does the RAM use a different type of rear axle?
