2003 Grand Caravan speedometer problem
Old 07-03-2009, 12:26 AM
tomoszo's Avatar
tomoszo
tomoszo is offline
Default 2003 Grand Caravan speedometer problem
2003 Grand Caravan speedometer problem. Sometimes when starting my engine 3.3 engine, my speedometer go completely clock-wise 360 degrees until it hid the stop peg. Sometime it gets stuck in that position; what can cause this problem?
Old 07-04-2009, 09:50 AM
vangonebuy's Avatar
vangonebuy
vangonebuy is offline
See if this helps.
With the van off and key removed, press and hold the odometer button until the gauges start a reset/diagnostic sequence.
Old 07-07-2009, 12:28 AM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
You can try what vangonebuy said, and if that doesn't work, try removing the iod fuse for 5 mins and push back in. If still have problems then get the van to the dealer, you could have problem with circuit board.
Old 02-07-2010, 03:05 AM
rabtrfld's Avatar
rabtrfld
rabtrfld is offline
Default self-test with KEY REMOVED?
Skeptical that instrument self-test can be performed with key removed in OFF.
Old 02-08-2010, 09:03 AM
tomoszo's Avatar
tomoszo
tomoszo is offline
The dealer wants to remove my speedometer and send it out to be repaired and charge me over a $1000 dollars [I will be out of my van for a long time]. I don’t think this is right.
Old 02-08-2010, 10:27 AM
master tech
Did you try the self test that rabtrfld had said to do? I would try that first.
Old 05-10-2010, 08:13 PM
thecardoctor's Avatar
thecardoctor
thecardoctor is offline
I had this problem on a 2001 caravan 3.3 ltr engine. The problem was the 12 volt battery shorting internally. Replacing the battery cured this and other gauge problems, but I had to remove safety shield from front of gauges and manually return speedo needle to start position.
Hope this info is helpful to you. The car doctor.
Old 01-21-2011, 03:24 PM
spike55's Avatar
spike55
spike55 is offline
Did you check out the speed sensor, which is located on the transmission. My sensor was loose and the speedometer was bouncing between 0 and 65 and back. My mechanic put plugged in the SNAP-ON diagnostic computer which indicated the problem. Have you checked it out with computer?
Old 01-22-2011, 12:15 AM
master tech
Welcome to DF
This is an old post, And haven't heard from the member with the speedo problem.
Old 01-22-2011, 12:29 PM
spike55's Avatar
spike55
spike55 is offline
Default 2003 Dodge Caravan rear hatch problem
Since the speedometer problem has been an old, could you help me with mine? My 2003 Dodge Caravan power lock on the rear hatch keeps on trying to open and close. When it does this, my interior light and instrument cluster indicator lights up. It does this periodically within my garage. Seems like someone is inside the vehicle, opening and closing the power locks. Ghostly!!! The dealer's mechanic suggests that there may be some corroded or bad contact with the lift gate ajar switch. This has happened ever since the weather dipped to -40 below. Do you think I need a new part or try taking the interior panel off and clean up the switch?
Quick Reply: 2003 Grand Caravan speedometer problem
