Rear pinion seal leak?
Old 07-01-2009, 04:27 PM
mattg1500's Avatar
mattg1500
mattg1500 is offline
Default Rear pinion seal leak?
I have a leak on my rear pinion seal and was wondering how to replace it. can i just drop the driveshaft unbolt the yolk and replace the seal?
Old 07-01-2009, 04:32 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
a post from the other day https://dodgeforum.com/forum/3rd-gen-ram/205818-leak.html
The link won't work for me???? I'll bump up the thread. It says LEAK
Old 07-01-2009, 06:01 PM
Gone Fishin's Avatar
Gone Fishin
Gone Fishin is offline
Yes, you can do as you said in your post, but, the pinion nut MUST be in the exact place it was before you removed it when your done. It sets the pre-tension and crush washer for the pinion.
Old 07-01-2009, 07:26 PM
mattg1500's Avatar
mattg1500
how would i ensure it is in the same position? i was going to just torque it when done.
Old 07-01-2009, 09:17 PM
Toefur's Avatar
Toefur
Toefur is offline
mark with a wax pencil
Old 07-01-2009, 10:33 PM
Fris's Avatar
Fris
Fris is offline
I used a paint marker on mine
Old 07-01-2009, 10:56 PM
Rebeltilldeath3's Avatar
Rebeltilldeath3
Rebeltilldeath3 is offline
This.
Or just buy a new stake nut since technically they can't be re-torqued.
Old 07-01-2009, 11:36 PM
dirtydog's Avatar
dirtydog
dirtydog is offline
Moderate User
Since my link didn't work and you didn't read the other thread i bumped for you. here was what I posted.
You have to make sure you retighten the big 32mm nut holding the flange the same way you remove it. If you tighten it too much or not enough you can mess with the backlash of the gears, or so I've heard.
Originally Posted by Dirtydog
10-15ft/lbs for an old crush collar like you have is what I have found out there for specs. Going the cheap easy route like you stated is not the correct way, but most garages will do it that way because nobody wants to spend $800 for one lousy oil seal repair. The reason is because the collar is suppose to be seated without the carrier inside the rear diff by the amount of rotational drag.
Now as easier way is to mark the nut and yoke. Then, count the number of turns it took to remove the nut. Replace the seal. Re-install the nut to the position in which you took it from. Tighten it a little bit (less than 1/8 of a turn) past the original markings. This is a better way to do things so to keep near the same drag as before. But the true way is to remove the entire rear diff guts and start from scratch! Of course i wouldn't go that route even if it was my own truck. i would just mark the nut, count the turns and be on my way. No actual need for torquing at that point.
The crush collar tightening is one of the most important things to do in a rear diff to keep everything harmonized.
Old 07-02-2009, 06:49 AM
RubberFrog's Avatar
RubberFrog
RubberFrog is offline
good info dog
Quick Reply: Rear pinion seal leak?
