A/C blows hot air
Old 06-25-2009, 10:20 PM
johnyredd99's Avatar
johnyredd99
johnyredd99 is offline
Angry A/C blows hot air
A/c used to blow ice cold air until a week ago I went into store for 10 min. and left the truck idling. When I came out of the store to get into my ice cold truck. It was hot. I tried to re charge with freon but the gauge says its full. Yesterday it blew cold air for about 10 min. then hot. Please any help. Its not getting any cooler out. 1995 ram 2500
Thanks
Old 06-25-2009, 10:30 PM
dodgeram2001's Avatar
dodgeram2001
dodgeram2001 is offline
is ur compressor clicking ?
Old 06-26-2009, 07:57 AM
bucd's Avatar
bucd
bucd is offline
Mine went out yesterday. Mine may be a slow leak though. My compressor still kicks in and out. When you check the pressure with the AC on, does the compressor come on? The pressure that you see may look normal if the compressor is not kicking in. So make sure you can hear it click.
-D
Old 06-26-2009, 12:12 PM
Sheriff420's Avatar
Sheriff420
Sheriff420 is offline
as soon as you turn the ac on the compressor should turn on. with the truck running look at the clutch on the front of the compressor, it should be sitting there doing nothing. turn on the ac and look at the clutch on the front of the compressor, it should be moving with the pulley. if not then its probably either a bad electrical connection to the compressor, maybe a fuse/relay, or the compressor took a dump on ya.
Old 06-27-2009, 12:09 AM
johnyredd99
nothing from compressor. Could i possible of over filled system and that would shut down compressor?
Old 06-27-2009, 12:28 AM
Sheriff420's Avatar
Sheriff420
by nothing do you mean that the clutch doesn't engage when you turn on the ac? if so i'd swap the horn (or fog light) and the ac clutch relays (if the horn/fog lights work) to see if its that, if it is then you can get a new relay at napa for around 10$. if not then i'd say that either the clutch is shot and i think you can get a clutch rebuild kit to avoid having to buy a whole new compressor or maybe you aren't getting power to it for some reason like one of the wires being rubbed through. first thing i'd check is that relay though. and you shouldn't have more than 45 psi in the system but i don't believe it'd shut off the compressor.
Old 06-27-2009, 12:51 AM
Ram15002ndGen's Avatar
Ram15002ndGen
Ram15002ndGen is offline
There is a safety built into most A/C compressors and they shut off, or won't engage if the pressure falls below 20psi. Try the relay first and it that doesn't work try putting a gauge on the low side and and see how low it has gone. If neither of those works then you need a new clutch or compressor.
Old 06-27-2009, 04:29 AM
dodgeram2001
most of the time its going to be the compressor but thats just me because every time the AC is not working its always the compressor , but thats just me so just a lil hint . But it could be other things though , Just not my luck . Hope u found your problem.
Old 05-15-2014, 08:48 PM
Irishman69's Avatar
Irishman69
Irishman69 is offline
Default 2000 Dodge Ram
I have the same problem. My a/c blows hot air. Replaced the compressor, recharged system but still have no cold air. Could it be one of the actuator doors in the dash... Please help thx
Old 05-15-2014, 10:02 PM
stewie01's Avatar
stewie01
stewie01 is offline
I suspect my blend door is toast, I only get heat regardless of what setting it's on.
So I just bypass the heater core in the summer months and I have nice COLD AC!
Quick Reply: A/C blows hot air
