cold transmission slipage
Old 06-25-2009, 07:47 PM
roberson's Avatar
roberson
roberson is offline
Default cold transmission slipage
On my 1990 B250 318 V8 van, I recently had both U-joints replaced and a complete transmission flush, refill, filter and gasket job with ATF+4. I'm pretty sure that this is the first time for a flush and refill. I feel that the shop is quite reputable. The mechanic mentioned that there was "alot of metal in the pan". The transmission did not slip or act funny prior to the flush/refill. Now when it is cold, the transmission will hesitate and slip a bit. Once it warms up, back to normal. Smooth sailing. Should I go back and ask them to adjust the transmission bands? It is not leaking nor is the fluid low. Am I looking at a potential rebuild?/replacement? Any input would be very helpful.
CHEERS!
roberson
Old 06-25-2009, 11:18 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
It could be because they used ATF+4, which is a synthetic fluid. Although ATF+4 can be used, the tranny did not have it in it's system until recently. Your tranny just might have to live on ATF+3, which is not a synthetic fluid.
Old 06-28-2009, 12:22 PM
roberson's Avatar
roberson
roberson is offline
Thanks for your reply, would you suggest that I return to the transmission shop and have them re-flush, filter, gasket, and fill with ATF+3? Is ATF+3 still available? Also should I assume that I do not need to adjust the transmission bands and that it is just a fluid issue?
Thanks again!
roberson
Old 06-29-2009, 11:10 AM
alloro's Avatar
alloro
alloro is offline
I would first talk to them about the symptoms and see if they have any ideas. Adjusting the bands are standard practice whenever the fluid/filter is changed. If they didn't adjust the bands, they should have.
Old 07-25-2009, 06:41 PM
2bTim's Avatar
2bTim
2bTim is offline
CHEERS!
roberson
Hi Roberson, I had a 250 94 Dodgeram with 115k and the tranny would slip a little when cold. I went to a supposedly very good transmisson man and he told me that the reason it was slipping was because thev torque converter didn't staart circulating the fluid until it was taken out of park. So maybe you could try taking it out of park after cranking and let it warm up a little first... It worked for me...god luck..
2bTim
Old 08-29-2009, 10:43 AM
roberson's Avatar
roberson
roberson is offline
2bTim, Thanks for the suggestion. I've been using your suggestion and, so far, it seems to be working out. Thanks for the help!
CHEERS!
roberson
Quick Reply: cold transmission slipage
