Brake Warning Light
Old 06-23-2009, 07:45 PM
HellOnWheels's Avatar
HellOnWheels
HellOnWheels is offline
Default Brake Warning Light
Today I saw my brake warning lights come on when I start the truck and they don't go out. Both the brake light and the anti-lock warning light. I did a quick google search and noticed some people taking about this problem being caused by a bad "speed sensor". Another symptom is the speedo gauge doesn't work at real low speeds. And in my opinion my speedo has this problem.
I don't know if 1990 trucks have this problem though or if it was only something newer trucks have (this speed sensor thing).
Any suggestions?
Old 06-23-2009, 08:28 PM
kev2's Avatar
kev2
kev2 is offline
year model eng color etc......
Old 06-23-2009, 08:34 PM
HellOnWheels
it's a 1990 D150 Ram 2wd 318ci. auto w/overdrive standard cab long bed
Old 06-24-2009, 07:41 AM
SEAL's Avatar
SEAL
SEAL is offline
The RAWL (Rear Wheel Anti Lock) brake sensor is in the rear differential and has nothing to do with the speedometer. The RWAL microprocessor will store and display one code at a time when the light is on. The code (1-15) can be read by the number of flashes on the RAWL light when the RWAL diagnostic connecter is grounded. The diagnostic wire is a black 18 gauge wire that comes off pin #5 of the electronic brake control module.
Old 06-24-2009, 12:05 PM
nemesis_SS's Avatar
nemesis_SS
nemesis_SS is offline
our trucks have ABS? back wheels only? i never noticed it
Old 06-25-2009, 05:50 PM
power ram's Avatar
power ram
power ram is offline
Default yes they did
89' to 93' on the 1st gen dodges had rear anti lock brakes.
Old 06-26-2009, 03:14 AM
nemesis_SS's Avatar
nemesis_SS
thats really wierd. i noticed they stop nice in the snow for old trucks, but ive never felt the abs
Old 07-09-2009, 10:09 AM
Kcrest's Avatar
Kcrest
Kcrest is offline
I have noticed the same thing on my 2000 Durango. The 2 lights (anti-lock and E-Brake) are lit and the speed-o does not register anything below 20mph. I took the truck back to the guy we got it from and he said that the 2 problems may not be related. I think they are. So, if the problem is a bad speed sensor, how easy of a fix might that be?
Old 07-09-2009, 11:21 AM
SEAL's Avatar
SEAL
SEAL is offline
The E-brake has nothing to do with the antilock system or its speed sensor. If the parking brake light is on it is either a bad or miss adjusted switch which is on the parking brake peddle. This switch only monitors the position of the peddle and not the brake itself.
Old 07-10-2009, 12:53 PM
HellOnWheels
Kcrest, here is some info that may help you https://dodgeforum.com/forum/1st-gen...ight-help.html
Or you can google your vehicle and year and "speed sensor" and abs warning light.
My problem is all the info on that subject seems to be related to newer dodge vehicles. I don't know if any of it relates to pre-93 vehicles.
My mechanic told me the reason my warning lights are on is because something is wrong with the abs system but he didn't think the truck itself is worth putting the money into looking into what the issue is exactly.
Anyway, for your vehicle if it is a speed sensor problem, everything I've read about it says that it is a cheap and easy fix to do.
Quick Reply: Brake Warning Light
