1st Gen Intrepid 1993 through 1997 Intrepids
Solenoid Pack
Old 06-23-2009, 09:23 AM
lennemann23's Avatar
lennemann23
lennemann23 is offline
Default Solenoid Pack
I know that it is located inside of the transmission, but where is the connector that the wire connects to on the outside of the transmission?
Old 06-25-2009, 08:35 PM
DESIREESAVENGER's Avatar
DESIREESAVENGER
DESIREESAVENGER is offline
On top of the trans toward the passenger side. You don't need to take the connector off to replace the pack. It will come apart when you remove the valvebody.
Old 06-26-2009, 12:13 AM
lennemann23
I will look for it. If I do have to replace it, do I have to take the pan off?
Old 06-28-2009, 01:42 PM
DESIREESAVENGER
You have to take the pan down amd drop the valve body. It's mounted on top of the valve body
Old 06-28-2009, 06:13 PM
lennemann23
Someone told me at the auto parts store that it was mounted on top of the transmission.
Quick Reply: Solenoid Pack
