Old 08-06-2015, 01:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System
Print Wikipost
How to replace thermostat in 2000 SLT ?
Old 06-23-2009, 05:42 AM
98durangoSLT's Avatar
98durangoSLT
98durangoSLT is offline
Default How to replace thermostat in 2000 SLT ?
Im going to replace the thermostat in my 2000 Durango SLT to hopefully solve the problems i posted in another thread. First would be what thermostat do i need to get? and second how do i install it ? Any help is greatly appreicated
Old 06-23-2009, 10:20 AM
Dans01Durango's Avatar
Dans01Durango
Dans01Durango is offline
You'd have to get at least two gallons of anti freeze just in case cause you're gonna lose some when you drain the radiator. On my D, the t-stat is located on the bottom hose coming from the rad. In my situation, I'd have to get under the engine and disconnect the hose from the t-stat. The t-stat should be held on by two bolts. The recommended replacement would be an 180 degree t-stat. While you're down there why not replace the hose and replace the factory clamps w/ screw-type hose clamps? Wouldn't hurt but would certainly help... Just my .02, HTH.
Old 06-23-2009, 06:20 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
What engine?
Get a 180 degree T-stat replacement.
Old 06-23-2009, 06:45 PM
hydrashocker
I'll just give a piece of the 2000 Service Manual I'll attach.
File Type: pdf
Old 06-26-2009, 09:54 AM
Dans01Durango
Cool, do you have one for an 01 4.7???
Old 06-26-2009, 03:18 PM
hydrashocker
Should be the same.
To answer your question, no I don't have a 2001 service manual in the D but i got it in Ram and Dakota.
Old 06-26-2009, 04:49 PM
Dans01Durango
Meh, should be the same layout...
Old 06-27-2009, 12:57 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Use a stock replacement stat on the 4.7l and remember to burb it afterwards!
IndyD
Quick Reply: How to replace thermostat in 2000 SLT ?
