reverse lights dont work need help
Old 06-21-2009, 11:13 PM
Frogsnot's Avatar
Frogsnot
Frogsnot is offline
Default reverse lights dont work need help
Alright so when i bought my truck the reverse lights didnt turn on at all. (something i didnt notice when i bought it from the dealership my bad) a friend told me and for awhile now ive just put it off until now. ive been doing work on my truck and decided it was about time to fix the reverse lights. so i checked to see if simply both bulbs were bad. their brand new, i tested to see if i got power to the plug for the bulbs and nothing. (the truck was in reverse).
So my ? is is their a sensor somewhere by the shifter that turns the reverse lights on? and if so is it bad? or is their something else it could be?
Darion
Old 06-21-2009, 11:17 PM
wjxavier's Avatar
wjxavier
wjxavier is offline
could be a fuse...if you're not getting power to your lights, it could also be a crappy wire connection. thats usually what it is for me when my lights go out.
Old 06-21-2009, 11:33 PM
Frogsnot's Avatar
Frogsnot
Frogsnot is offline
checked my fuses and my wiring seems to be ok i really cant tell no power is running through it. my trailer lights and every other light including my stupid license plate lights all work.
Old 06-22-2009, 01:32 AM
99DRAM31887's Avatar
99DRAM31887
99DRAM31887 is offline
its ur neutral saftey switch i had a 99 with the same problem i went to autozone and paid like 10 bucks for a new one and it took me like 5 mins in my drive way and they worked after that ill bet money its ur saftey switch
Old 06-22-2009, 05:35 AM
jjtroutbum's Avatar
jjtroutbum
jjtroutbum is offline
Would be my first guess.
Simple check for neutral park reverse light sensor is to be able to start/turnover the truck in any gear besides park or neutral. Just don't try it parked near anything.
Old 06-22-2009, 01:59 PM
98BlueSport's Avatar
98BlueSport
98BlueSport is offline
I dont have any reverse lights either. My i think my wireing harness is a little messed up, because if i have a trailer hooked up the trailer lights stay on all the time.
Old 06-23-2009, 12:14 AM
99DRAM31887
well my 99 would still only start in neutral or park but the reverse lights going out is a sign of the switch going out and its real easy to replace its on the drivers side of the tranny u just need a deep socket i just cant remember what size and it comes out along with some t.fluid and just put the new one in and top ur tranny off
Old 06-23-2009, 12:16 AM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
What about bulbs?
Old 06-23-2009, 04:01 PM
Frogsnot's Avatar
Frogsnot
Frogsnot is offline
alright ill try that, why does it leak transmission fluid? and my bulbs are good if that ? was to me.
Thanks
Old 06-23-2009, 05:42 PM
Ram15002ndGen's Avatar
Ram15002ndGen
Ram15002ndGen is offline
It leaks tranny fluid because it is connected into the tranny. Have your new switch near you ready to go with some teflon tape on the threads ready to install the minute you take out the old one and you should have minimal leakage. There arent too many choices, fuses, wiring, harness, bulbs, neutral switch, that's it. One of those is bad. I replaced a neutral safety switch on a 1970 AMC and it was easier cause it was inside the passenger compartment on the steering column.
Quick Reply: reverse lights dont work need help
