Just dies while driving, then "no bUS" and engine light
Old 06-06-2009, 04:03 PM
mini_mull's Avatar
mini_mull
mini_mull is offline
Default Just dies while driving, then "no bUS" and engine light
Hi, I have a 99 dodge ram van with 70K miles. It's a conversion with an TV/VCR and extra lights, etc. We bought it from my in laws when they were ready to trade it in and haven't had any problems with it until now. Today for the third time I'll be driving usually around 45mph and the engine just dies. All the gauges read in normal ranges before it dies. I pull off on the shoulder (thank goodness it always dies where there is a shoulder) turn off the ignition and wait. If I immediately try to crank it over again it turns over, but won't start and all the gauges don't work and the digital odometer says "no bUS" and the engine lights come on. If i let it sit for a few minutes before I try to crank it, then it starts right back up just like there was never a problem at all. I know the "no bUS" means the computer system isn't communicating, but I'm not sure if that is the root of my problem or not. I've taken it to our regular mechanic with no luck, and I'd really rather not spend the money on the dealer if I don't have to. Any ideas? Thanks in advance!
Old 06-06-2009, 04:50 PM
alloro's Avatar
alloro
alloro is offline
Van & CUV Section Moderator
Sounds like your computer is failing when it gets hot.
Old 06-06-2009, 07:07 PM
mini_mull's Avatar
mini_mull
Uhg! So would that most likely mean the computer is going bad or something else is getting too hot and shorting it out?
Old 06-06-2009, 07:46 PM
alloro's Avatar
alloro
alloro is offline
It most likely means the computer is going bad.
You can get a used one fairly cheap here, just make sure you match up the number on the computer with any replacement one.
http://www.car-part.com/
Old 06-07-2009, 09:02 AM
kev2's Avatar
kev2
kev2 is offline
before throwing out the PCM lets try trouble shooting
any codes stored- might give direction
remote starter or aftermarket alarm - always problematic
any problem below 45mph- can you operate allday below 45?
there are conditions where the pcm will shut down
interupton of 5v - corossion OR after commanding a device ie egr - od- etc that circuit is shorted
the referance to above 45mph needed to set condition suggest a "down stream" problem... being sunday cannot get troubletrees.
most likely all test will begin "connect DRB" SORRY
Old 06-08-2009, 03:14 AM
mini_mull's Avatar
mini_mull
Default died at 25mph today
Hi guys thanks for all the ideas. Just wanted to mention it died today half way down my street going 25mph. Is there any way to check for trouble codes wthout a scanner? BTW, we've had a lot of static electricity in the van for the last few months and some problems with the conversion lights and tv/vcr. Could some electrical short be causing the problem? Do these clues help or bring anyone to a new conclusion?
Old 06-08-2009, 09:50 AM
alloro's Avatar
alloro
alloro is offline
Turn the key on,off,on,off,on and watch for trouble codes to be displayed on the digital odometer.
Old 05-20-2011, 12:34 AM
BoxcarNY's Avatar
BoxcarNY
BoxcarNY is offline
I have the same problem -- it causes my engine to stall while driving. It happens randomly once the engine reaches peak operating temp. I usually get it going again by pushing down on the third cluster plug on the PCM located (what a great design idea!?!?) right above the hot engine. Sometimes I have to wait till the temp drops a little. I turn the key to RUN position then push down or wiggle the cluster plug until I hear the rely click in the fuse box. Then it usually starts. I cannot seem to figure out if it's a bad connection on the plug (seems like a hundred wires!) or in the receptacle on the PCM. Sometimes it won't happen for a day or two but it always dies when I hit slow traffic. I've cleaned the contacts on both sides with no change.
Another marveous MOPAR design flaw.
I have the treatment but not the cure.
Does anyone have a definative cure for this?
Old 05-20-2011, 08:00 AM
markaylasdad's Avatar
markaylasdad
markaylasdad is offline
Hello all. A good friend of mine is having the same problem with his 2000 dodge ram 3500. Starts and runs untill it warms up,then dies and won't start. It will crank,but no spark.I replaced the crank sensor,coil , dist.pick-up and ultimately the E.C.M. Got a call this morning that it died again.Does this van have a cam sesnor? and could this be the problem? I am also wondering if it could be a ground problem.
Old 05-20-2011, 09:31 AM
alloro's Avatar
alloro
alloro is offline
Originally Posted by BoxcarNY
Does anyone have a definitive cure for this?
Absolutely...
http://www.youtube.com/watch?v=Ujm9nsJYEqg
Quick Reply: Just dies while driving, then "no bUS" and engine light
