What are the symptoms of a bad map sensor
Search Youtube for how to check a MAP sensor. There are some very good tutorials on there (thats what I did).
A bad MAP sensor can potentially cause all sorts of issues...
1. A rich or lean fuel mixture. You may notice a gas smell even after warm-up and/or pinging at random times or all the time or whenever.
2. Excessive fuel consumption (rich)
3. Rough idle
4. Hesitation
You will especially notice the hesitation off of idle when you first give it gas. The engine may even die if you don't give it enough gas off of idle.
Usually when a MAP goes bad, you get a CEL and a code for it.
3. Rough idle
4. Hesitation
3. Rough idle
4. Hesitation
3. Rough idle
4. Hesitation
on
No way. This is part of the EFI system. If your lights are going dim, that's either a FAULT with the charging system or, a poor connection someplace either due to a bad ground or HOT.
Check and clean all BAT connections, all ground connections first and retest.
If these connections are showing high resistance, a voltage drop will occur and, depending on how low the voltage is dropping, there's a possibility that it is also affecting the PCM.
CM
CM
on
The MAP sensor is what measures the manifold pressure. Manifold Absolute Pressure sensor. This is another master sensor that provides voltage to the PCM. This voltage reading determines in part, what the A/F mixture should be.
In addition to that, it also plays a part in determining the spark advance and injector pulse width. The PCM uses the MAP sensor to determine or calculate the following:
- Manifold Pressure
- Barometric Pressure
- Engine Load
- Injector Pulse Width
- Spark Advance programs
- Shift point strategies for specific auto transmissions
- Idle speed
- Decel fuel shutoff
CM
- Manifold Pressure
- Engine Load
- Idle speed
CM
Hi everyone i need help i have a 98 durando i bought it cuz good price and iam a fairly good mech or least i thought i was till this can into my life lol
my 98 had starting problems the old owner took to dodge the said after hours of testing the the think it needs a pcm ( but cant garintee it it is that ) so the 500 plus 800 for pcm with no garintee she says no way tows it home puts it for sell i buy thinking iam this great mech il fix it lmfao this dodge is winning. wen i first got it home no start at all this is a list of what i have done
#1 used pcm
#2new crank sen
#3 new can cap and rotor
#4 got oringenle pcm reflashed
#5 picked up anoth used pcm ( that a totle of 3 ) now
#6 i get two more reflashed
ok now what it is doing it starts then dies right away
please if there is any body out there that can piont me it the right way i dont like dealer ships there just part replacers not mech and i know they know this a reacureing problem they dont care as long as you need them i think we as dodge owner get to gether as one grope and solfe this problem i think with all our knolage we could my email is robinhood-25@hotmail.com or robert steffen on face book iam the one with the two dogs in pic look me up lets chat about the durango and solf this thing
#1 used pcm
#2new crank sen
