popping/knocking noise
Old 05-19-2009, 08:54 AM
jstmahoney's Avatar
jstmahoney
jstmahoney is offline
Default popping/knocking noise
IN the last two days on our little road trip, i noticed on our caliber, a knocking or popping noise. It only does it when the wheel is turned and you accelerate.And it seemed more so when the wheel is turned to the left. I am going to give the dealer a call in a few hours when they open and see if i can get it in. It's still under warranty, so as far as i'm concerned, its dodges problem. I just wanted to know if anyone else has experienced this and or if any ideas as to what the issue is. thanks
Old 05-19-2009, 05:18 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
There is a TSB for possible loose bolts.
Here is the TSB
DODGE / CALIBER 2008-2009
DODGE / CALIBER AWD 2008
JEEP / PATRIOT 2009
JEEP / PATRIOT 4X4 2008-2009
JEEP / PATRIOT FWD 2008-2009
Service Bulletin Number : RRT-08-070
NHTSA Item Number : 10026829
Summary Description :
CHRYSLER: LOWER CONTROL ARM TO CROSSMEMBER MOUNTING BOLTS. VEHICLES WERE SHIPPED WITH FRONT LOWER CONTROL ARM TO CROSSMEMBER MOUNTING BOLTS THAT MAY NOT BE TIGHTENED TO SPECIFICATION. *PE
Our 09 makes this noise but only when it is below 20 degrees outside and only for about a mile or two until whatever it is warms up.
Old 05-26-2009, 03:08 PM
jstmahoney's Avatar
jstmahoney
Sure enough, dealer says RRT-08-070
Old 05-29-2009, 10:33 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Have they fixed it yet?
Old 06-01-2009, 07:10 PM
fcfanatic's Avatar
fcfanatic
fcfanatic is offline
I had this kind of problem on my honda model accord.
It turnes out to be cv gators. However if this occurs when heat/ temperatur is an issue I would check the bolts on the manifold. sometimes they get overtightend in the factory and pop.
Old 06-03-2009, 01:20 PM
jstmahoney's Avatar
jstmahoney
Yup! they fixed it and it rides much better. Had it repaired and had the tires rotated and the lojack installed, after almost a year!
Old 06-03-2009, 08:28 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Good deal. Was it the recall in question?
I drove the wife's the other day and all seems well for now.
Old 06-04-2009, 10:49 AM
jstmahoney's Avatar
jstmahoney
they said nothing about it being a recall. I just said its under warranty your responsibility.
Old 06-06-2009, 01:35 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
That's all that matters
Quick Reply: popping/knocking noise
