Radio stays on when I open the door
Old 05-17-2009, 10:02 PM
AK Rover's Avatar
AK Rover
AK Rover is offline
Default Radio stays on when I open the door
I apologize if this has already been covered but I wasn't sure how to word it so the search function would find something useful.
The problem I am having is that my stereo is staying on after I turn the key off and open the door. Until recently the system worked fine and would keep power to the stereo for up to 15 minutes or until a door is opened like it's supposed to. Now it seems to turn off the stereo system whenever it wants after I get out.
Has anyone run into a problem like this? Any ideas on what could cause it? Any ideas how to fix it without going to the dealer?
Old 05-17-2009, 10:25 PM
Alpheus's Avatar
Alpheus
Alpheus is offline
Is your dome light working normal when you open and close the door? Play around with the door switch and see if your stereo turns off...
Old 05-17-2009, 10:29 PM
sos's Avatar
sos
sos is offline
Do your lights come on when the door is opened? If not, I would check the door switch.
Old 05-17-2009, 10:30 PM
sos's Avatar
sos
sos is offline
Ok, next time I will refresh before posting a comment... D'oh.
Old 05-17-2009, 10:54 PM
MikeHTally's Avatar
MikeHTally
MikeHTally is offline
Sounds like the timer has been accidentally changed.
Old 05-17-2009, 11:00 PM
AK Rover's Avatar
AK Rover
AK Rover is offline
The dome light works fine. Comes on when I open the door and goes out after 15 seconds or so like it always has. Where are the door switches on an 07? I haven't seen a normal pin switch in the jamb like most vehicles have
Old 05-18-2009, 12:27 AM
raminator08's Avatar
raminator08
raminator08 is offline
this is still the factory stereo, right?
Old 05-18-2009, 01:02 AM
AK Rover's Avatar
AK Rover
AK Rover is offline
Nope, aftermarket Alpine deck. I've had the truck for almost 2 years, had the stereo installed about a week after I bought it and this is the first time I have had problems like this.
Old 05-18-2009, 07:22 AM
sos's Avatar
sos
sos is offline
Door switches are magnetic now I believe.
I would say to check the wiring of the radio - the radios are always supplied with power to retain memory, but there is a separate trigger that tells the radio when the truck is on or off. I'm guessing that's where your problem is.
Old 05-18-2009, 07:35 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
Yep, with an aftermarket deck it sounds like his HUs constant and switched power wires are both wired to constant to me.
Quick Reply: Radio stays on when I open the door
