truck starts then dies
Old 05-15-2009, 01:31 AM
rafter40's Avatar
rafter40
rafter40 is offline
Default truck starts then dies
2000 ram 1500 sport 360
my truck will start and then immediately die. i can force it to continue running by giving it gas, but when i take my foot off the throttle it just stops running. i thought it might be the fuel filter, or some other gas restriction, but i have to take the gas tank out to replace it? i dont know if this is a common problem but any help is greatly appeciated.
just some extra info, this just started happening today after my battery drained cause i left my damn lights on(i dont think it is related) and after trying to jump my car it still didnt work. randomly my truck started twice, but then wouldnt start again after i drove it for a lil.
Old 05-15-2009, 01:58 AM
xxxSportxxx's Avatar
xxxSportxxx
xxxSportxxx is offline
Sounds like it could be your Idle Air Control valve
Old 05-15-2009, 04:16 AM
jasonw's Avatar
jasonw
jasonw is offline
Site Moderator
Could also be the MAP sensor. I've unplugged my MAP before out of curiosity, and your problem is exactly what it did.
I'd check the IAC motor first, as it is cheaper to replace if its broken. Only about $40 or so. The MAP sensor is almost $100.
Old 05-15-2009, 07:08 AM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
remove IAC, clean the well in the back of the TB and make sure there is an open hole into tb. replace IAC. don't forget the o-ring. about $40-50 at and parts store.
Old 05-15-2009, 11:30 AM
rafter40's Avatar
rafter40
rafter40 is offline
i was at a quarter tank and just added 8 gallons of 93 octane fuel from shell. it seems to be running a lot better, but i was considering replacing my iac and tps before this happened. maybe it will help aswell. i havent driven it enough to say problem fixed. another symptom i noticed before i went to the gas station was that when it was idling fine, and i reved it, the engine had a hard time continuing to run after that. thanks again guys
Quick Reply: truck starts then dies
