2002 Dodge Ram 1500 Camshaft Sensor
Old 05-05-2009, 07:29 PM
lindaanne's Avatar
lindaanne
lindaanne is offline
Exclamation 2002 Dodge Ram 1500 Camshaft Sensor
Can anyone please tell me where the cam shaft sensor is located on my truck and how do I get to it to change it? It is a 2002 Dodge ram 1500
1\2 ton, 2wd 8 ctlinder. Thank you>
Old 07-21-2009, 04:10 PM
mel's Avatar
mel
mel is offline
Default Camshaft sensor
Can someone please tell me where to find the camshaft sensor on a 2002 Dodge truck . Thank you
Last edited by mel; 07-21-2009 at 04:46 PM. Reason: Urgent need answer ASAP please
Old 08-13-2009, 08:34 AM
GMPXpat03's Avatar
GMPXpat03
GMPXpat03 is offline
Default Camshaft Sensor on 5.2L
Camshaft Sensor is also known as a magnetic pickup coil. This is located inside the distributor on a 5.2L. Changing this sensor does not require removal of the distributor.
Your biggest hassle is reaching it.
Good Luck.
Old 12-14-2009, 10:50 AM
JMonty's Avatar
JMonty
JMonty is offline
I called the Auto Parts store and they said that it was located on top of the Transmission behind the carburator and distributor.
Old 12-18-2009, 11:57 AM
Todd-USMC's Avatar
Todd-USMC
Todd-USMC is offline
Default Camshaft Sensor Dodge Ram 1/2 ton V8 4.7L
Linda,
I just changed my head gaskets and had to pull my engine apart so I know exactly where it is located. It is located on the bottom of the passenger side head towards the front (grill). The easiest way to get to it is to take off your passenger side heat sheild (the black cover where your wheel is) and it will be right there. Or you can just reach under there from the top of the engine also. You are going to unplug the wire attached to it and then it just pulls right out. Make sure you don't twist to get it out. Gently jiggle it back and for to get it lose. They are not cheap though... How do you know your's is bad?
Old 12-24-2009, 12:26 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
You are in a dead area and you need to post in your era of year of make.
3rd Gen Ram
2002 - 2008 Rams
~Rustin~
Quick Reply: 2002 Dodge Ram 1500 Camshaft Sensor
