Clicking noise from middle pulley when motor idling???
Old 05-04-2009, 01:24 AM
hovie's Avatar
hovie
hovie is offline
Default Clicking noise from middle pulley when motor idling???
When my truck is idling the middle pulley that the serpentine belt goes around will turn than stop than a few seconds later turn and stop and so on and so forth. It's noisy. Is this suppost to happen?
Thanks
Old 05-04-2009, 01:58 AM
iwhitne's Avatar
iwhitne
iwhitne is offline
are you sure it's not the A/C compressor turning on and off?
Old 05-04-2009, 02:04 AM
hovie's Avatar
hovie
hovie is offline
I actually thought it was my A/C compressor. Is it supposed to turn on and off every few seconds like that?
Old 05-04-2009, 02:22 AM
95RamIT's Avatar
95RamIT
95RamIT is offline
yea if its your compressor it will come on and off. when it starts and stops it makes a clicking noise.
not the exact one in your truck but the idea;
http://www.2carpros.com/images/ac_compressor_clutch.jpg
Old 05-04-2009, 10:21 PM
nolazach's Avatar
nolazach
nolazach is offline
check your R134a levels, you can get a can with a gauge on it for like $20. If you are a little low on freon your compressor could cycle more, it could also need more oil. Of course if you are low, then that means there is a leak, but usually the can stuff will have some leak finder and sealer in it.
I was thinking when I read the thread title it was going to be the Water Pump, it makes a noise when it is bad, but you are describing the compressor.
Old 05-04-2009, 10:43 PM
dhvaughan's Avatar
dhvaughan
dhvaughan is offline
mine cycles on and of frequently. its annoying, but i think its normal.
Old 05-05-2009, 11:51 PM
88dakv6's Avatar
88dakv6
88dakv6 is offline
Its not, you are low on freon.
Old 05-06-2009, 06:46 AM
hovie's Avatar
hovie
hovie is offline
My A/C does not get cold so I know I'm low on freon but how well do those cans work? Is it better to have the system drained completely somewhere and re-filled? I know they have machines for just that.
Old 05-06-2009, 11:16 AM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Unless you have gauges and a pump you are better off taking it somewhere. They will check for leaks also. And if yours is low, most likely it's the evap core.
Quick Reply: Clicking noise from middle pulley when motor idling???
