How do i know if my Rear Diff is going out
Old 04-28-2009, 07:26 PM
Steel Horse's Avatar
Steel Horse
Steel Horse is offline
Default How do i know if my Rear Diff is going out
How can i tell when its going out. What kind of signs will i get?
Old 04-28-2009, 07:54 PM
DODGEIT105's Avatar
DODGEIT105
DODGEIT105 is offline
Well there are signs and symptoms for several rear end problems. Some might be minor in nature or could be a major repair. Some common problems vibrations that can't be attributed to anything else. Possible cause could be a pinion bearing going out. Or if it is a locker type it could be the clutch packs coming apart. If it is a locking type differential and it feels like it binds some in a sharp turn then it could be that it needs to be serviced and limited slip additive added to it. Since you didn't describe what yours was doing it is hard to say what could be wrong with it. I would suggest having it serviced. It will shed some light on what it could be. Look for metallic pieces on the magnet on the bottom of the housing after the fluid is drained. A good inspection of the
gears and fasteners can be helpful.
Old 04-29-2009, 09:02 AM
Steel Horse
I have a 01 5.9 off road edition. When im in 4 wheel drive Low and i turn the front of the truck will hop, as if its skipping gears. I can be doin 2 MPH and it does it. So i lied its the front diff and i have 4:10. It dosnt do it near as bad in 4H but in 4L its horriable. Any ideas what it might be?
Old 04-29-2009, 09:53 AM
ophidia's Avatar
ophidia
ophidia is offline
That's normal. It's the front tires binding up, which it will always do when turning on a surface with good traction. It's just more noticeable in 4WD Lo because more torque is making it to the wheels.
Old 04-29-2009, 11:50 AM
Marksman's Avatar
Marksman
Marksman is offline
Agree. I bet if you were in sand or in mud you wouldn't even notice. When you turn, all the wheels want to go different speeds on account of the distance they need to travel. (outside vs inside thing). The slow wheels kinda spool up and spin to catch up.
I assume no noises or any other problems.
Old 04-29-2009, 02:59 PM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
Yep mine dose the same thing. We I took my truck for a test drive I was like oh no I'm not getting this one. But than I found out it was normal so I got it. My grandfather has a jeep that he plow with mid 80's he said his is like a bucking bronco on dry ground.
Old 04-29-2009, 06:10 PM
Steel Horse
thanks guys so much
Old 04-29-2009, 06:26 PM
zman17's Avatar
zman17
zman17 is offline
Retired Moderator - RIP
Originally Posted by dodge15004x45.9
Yep mine (DOSE) the same thing. We I took my truck for a test drive I was like oh no I'm not getting this one. But than I found out it was normal so I got it. My grandfather has a jeep that he plow with mid 80's he said his is like a bucking bronco on dry ground.
DOES, DOES, DOES, DOES,DOES, LOL Repeat after me DOES, DOES, DOES. LOL
Old 04-29-2009, 06:44 PM
ophidia's Avatar
ophidia
ophidia is offline
Am, is, are, shall, should, be, being, been, was, were, will, would, has, have, had, do, does, did, can, could, may, might, must, ought!
Old 04-29-2009, 08:57 PM
dodge15004x45.9
Haha Real funny I'm flying yall the bird right now! I'm felling the love tonight!
Quick Reply: How do i know if my Rear Diff is going out
