Dashboard Removal
Old 04-26-2009, 07:51 PM
mblanco2000's Avatar
mblanco2000
mblanco2000 is offline
Default Dashboard Removal
I need to get behind the dash in the area of the A/C Controls. I took off the piece that goes under the steering column to get a better look. I then removed the piece just below the cup holder, it was all snaps that popped out. I figured I needed to start pulling stuff off from the bottom and working my way up to the A/C, but I am having hell getting out the cup holder, lol. Does anyone have a better method they could share on how to get behind the A/C panel area???
Can someone please help me out here? I would not think it would be all that hard. Thanks in advance.
Old 04-26-2009, 08:05 PM
Quig19's Avatar
Quig19
Quig19 is offline
on my 06 U just pull the radio bezel out along with the a/c controls.... it is held in by plastic clips... Do u have the cup holders that fold into the center below the radio and a/c controls??
Old 04-26-2009, 08:34 PM
mblanco2000
Yes I have the cup holders that fold up below the A/C controls. I just figured out how to get the cup holders out. There were two screws at the bottom, and then there were two more screws that were behind the panel when the cup holder was open that had to be removed. Now I am trying to figure out the next piece I need to remove after the cup holder. It is giving me fits.
Quig: What piece are you calling the radio bezel?
Old 04-27-2009, 07:37 AM
mblanco2000
The radio bezel is the piece that goes around the radio, the AC controls and has the cig lighter in it as well. That whole piece pops out, no screws. I used a screw driver to pry it out. Started from the top above the radio. Here is a diagram:
http://documents.victorytechnologies...oduct/8567.pdf
Old 06-11-2009, 10:13 PM
cirrus9's Avatar
cirrus9
cirrus9 is offline
Default 2006 dashboard
Whoa.... before you go prying the radio bezel out, please note that there are two screws underneath the bezel/above the cup holders that you just took out. Hopefully you didn't crack your bezel yanking on it.
Quick Reply: Dashboard Removal
