Old 08-06-2015, 12:13 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Front-end Knocking noise?
Old 04-25-2009, 08:00 PM
masshole's Avatar
masshole
masshole is offline
Question Front-end Knocking noise?
Hello everyone,
I'm having a problem with my front-end. Whenever I hit bumps or potholes etc., I'm getting a knocking noise coming from both front wheels. I jacked the front-end up to check if it was my ball joints - no issue there. I also checked my tie-rods too - same result. I'm thinking my shocks might be shot, I don't know.
I've had my 2.5 tcg leveling kit on for over a year know with the original shocks in place. So I'm wondering if this might be the culprit.
My truck currently has 43k miles on it. I'm taking it to a local shop this Monday to see what the problem may be. It could be the ball joints -or- tie rods, I wasn't to confident in how I tested them.
Any advise from the pro's???
Old 04-25-2009, 08:04 PM
Toefur's Avatar
Toefur
Toefur is offline
Sway bar end links...Im 99.99% sure that is your problem.
Old 04-25-2009, 08:09 PM
masshole's Avatar
masshole
masshole is offline
Never would've thought to think of that. What would be a good indicator or a test of some sort? Would there be any visual signs?
Old 04-25-2009, 10:23 PM
Toefur's Avatar
Toefur
Toefur is offline
They have a pivot like a ball joint...they wear out and make a clicking-knocking sound over sharp bumps....replace with Moog greaseable ones and they'll last way longer. As for checking them...un bolt them from the control arm and check the pivot on em....if they move loosely with little resistance they are shot. Check for damage to the rubber booots on em also. Hope this helps
Old 04-26-2009, 12:12 AM
hemidel's Avatar
hemidel
hemidel is offline
Try new shocks. Preferably a shock that is 2in. longer for the front to compensate for that new height.
Old 04-26-2009, 08:12 PM
masshole's Avatar
masshole
masshole is offline
What type of shocks do you suggest? Would anyone else have any other suggestions to my problem? I'm bringing it into the shop this Monday or Tues. the latest.
Old 10-06-2009, 09:51 PM
Tough Ram's Avatar
Tough Ram
Tough Ram is offline
I would go and try the sway bar end links. that is what i have to replace on my truck and i am having the same noise. that and they arent that expensive to replace either.
Old 05-12-2014, 04:43 PM
jimrcyr's Avatar
jimrcyr
jimrcyr is offline
Default new 2014 Journey struts make knocking sound
I bought a new Journey and it has less than 300 miles. The front end makes a knocking sound at low speed going over bumpy road. Not normal. Any suggestions?
Old 05-13-2014, 01:31 AM
Prismatic's Avatar
Prismatic
Prismatic is offline
With a 2.5 inch leveling kit the stock shocks have become limiting straps for the front end. The knock is the shock reaching full extension when the wheel travels down an extra two inches more than the shock was designed to move.
I had the same issue. Loud knock over potholes and bumps when I installed my leveling kit. New shocks 2 inches longer corrected the problem.
Old 05-13-2014, 11:47 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
I am sorry you are experiencing a knocking noise in the front end. I would recommend to contact the dealer for an appointment to diagnose the issue.
Quick Reply: Front-end Knocking noise?
