Oil Dip Stick
Old 04-16-2009, 12:19 AM
VOATMJ1's Avatar
VOATMJ1
VOATMJ1 is offline
Default Oil Dip Stick
Being a new Dodge truck owner, I have noticed that when I get oil changes, and the vehicle calls for 5 quarts (including filter) that when 5 quarts are put in, the oil reads waaay past the full mark on the dip stick, and reads about 3/4 of a quart high on the stick. The oil goes past " Do Not Overfill, and stops at the "O" on "See Owners Manual" printed on the dip stick which is way WAY past the full mark.
The dip stick is very long when I pull it out and I assume that it is the correct one. What is the story with the Dodge oil dip sticks reading high on oil changes? Or is it just me. Thanks!
Old 04-16-2009, 12:24 AM
dodge15004x45.9's Avatar
dodge15004x45.9
dodge15004x45.9 is offline
I put 6 in mine and it was ok. You also need to let the oil settle a bit as well that might help a bit.
Old 04-16-2009, 12:32 AM
VOATMJ1's Avatar
VOATMJ1
VOATMJ1 is offline
I check the oil once a month and after it sets overnight, and it always reads high and I have had multiple oil changes, same thing. I might take the stick into the dealer since it has numbers on it, to make sure that I have the correct dip stick in it.
On my Explorer's dip stick, 5 quarts is right on the full mark. So something is not right with my Dodge, if you guys when you do oil changes that your dip sticks are at the full mark and not way past it.
Old 04-16-2009, 07:28 AM
charlie1935's Avatar
charlie1935
charlie1935 is offline
I use the larger filter on mine and it takes 5 1/2 to the full line.
Old 04-16-2009, 07:48 AM
olyelr's Avatar
olyelr
olyelr is offline
It sounds to me like you may have the wrong dipstick. I have done a zillion oil changes on my truck (OK, at least 50 anyway) and it is always at the perfect level on the dipstick when I add 5 quarts. If you want I will measure the dipstick in my truck for you (2000 5.9) to confirm the length and the area of the correct fill line.
Edit: I took the initiative and went and measured it. It is (from bumping the blunt end of the handle that touches the tube) 32 1/2" - 33 7/8" in the "safe" area and 36" in total length.
Old 04-16-2009, 06:15 PM
Ram2K1's Avatar
Ram2K1
Ram2K1 is offline
Mine is on the money with 5 qts.
Old 04-16-2009, 07:27 PM
PurplDodge's Avatar
PurplDodge
PurplDodge is offline
Do you wipe the dipstick off first, put it back in and then pull it out to get the reading?
Old 04-17-2009, 04:47 PM
VOATMJ1's Avatar
VOATMJ1
VOATMJ1 is offline
Yep, I wipe it off and then stick it back in and check. On my next day off, I am going to take the dip stick into the dealer and have them look up the numbers printed on the dip stick to find out what exactly is going on and if I have the correct dip stick, which by the way it's reading, I'm sure I don't! This is strange, as it has the yellow top as other Dodge trucks that I see. Maybe I have V6 dip stick?? But I know that when the oil is on the letter "O" for Owners Manual, it's full.
Old 04-17-2009, 05:07 PM
Cereal Killer's Avatar
Cereal Killer
Cereal Killer is offline
Yellow top eh? Mine has a black top... although mines a '96 so who knows...
Old 04-17-2009, 08:25 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Maxx_Magnum is offline
I changed mine a few weeks ago and put 5 liters in it, and it put it about a quarter inch or so above the full mark
Quick Reply: Oil Dip Stick
