What are symptoms of loose timing chain??
Old 04-11-2009, 04:56 PM
milton mom's Avatar
milton mom
milton mom is offline
sounds like your timeings out.Check your spark at night for an orange or blue spark on your #1 spark plug.If your sparks orange your out one tooth on timeing chain.If its blue than its running to manufactres specs.Keep me informed hope this helps
Frank Guerra (10-12-2020)
  #22
Old 04-11-2009, 05:17 PM
milton mom's Avatar
milton mom
Wink
Originally Posted by 2shus
I have posted on this truck before and am about to my wits end. It just does not have the power it should. I drove home from work tonight and was driving into a headwind and was emabarrassing to have the pedal practically floored. (1998 W150 4X4 318 TBI 108,000 miles automatic No OD) The best way I could describe it is like it has apples stuck in the exhaust pipes. (It has new duals with cherry bombs and no cat). I have done several tune up procedures on it and cleaned the throttle body as well as ran mopar combustion chamber cleaner thru it. Has new computer, map sensor, O2 sensor, EGR valve, plugs, cap, rotor, wires, K&N air filter, coil, hall effect pick up coil, EGR valve. I have spent a great deal of time checking and looking for intake and vacuum leaks with a small handheld propane canister. I ran a compression check and all cylinders read between 140 and 150 lbs. I have checked out all of the leads for lack of power suggested in the haynes manual. My old 85 Dodge van with a 318 will run circles around this thing. Here is what has me stumped!!! When I attempt to set the timing on it, it runs horrible when it is anywhere near what the catalyst sticker calls for which is 10 degrees BTDC. The only way I can get it to run halfway decent is to set the timing by ear insted of using a light. I am unplugging the coolant sensor before attempting to adjust the timing. I usually see 9 and have not seen over 10 MPG even on the highway. It idles as smooth as silk, but does hesitate when engine is not fully warmed up. I drive this to work daily! I am wondering if the timing chain is real loose or if their is a problem with the distributor itself somewhere? I am open to ideas! Thanks.
Sounds like an electrical problem.When its dark pull #1 wire off. Stick screw driver in the plug wire and if you have an orange spark then your timmeings out if you have a blue spark than timmeings up to manufactures specs.keep me updated hope this helps
  #23
Old 04-11-2009, 05:29 PM
charlie1935's Avatar
charlie1935
charlie1935 is offline
I go with Chump on time for a timing chain and gears.
  #24
Old 04-11-2009, 05:45 PM
88dakv6's Avatar
88dakv6
88dakv6 is offline
The timing chain stretches with use and age, there is no way to properly time a worn engine, I have replaced tons of timing chains and gears due to "it just doesn’t have ***** anymore" replace it, time it, and you will see the difference.
  #25
Old 04-11-2009, 06:13 PM
83dodgeswb4x4's Avatar
83dodgeswb4x4
83dodgeswb4x4 is offline
For the price of a couple of gaskets, a six pack of beer, and an afternoon of enduring a few scraped knuckles, it is worth it to just pull the timing cover and check the chain. If its stretched to far, replace it, and if not, slap the cover back on and button it back up and move on.
  #26
Old 04-12-2009, 08:10 AM
SEAL's Avatar
SEAL
SEAL is offline
2 shus
I have an 89 same as yours with the exact same problem. I have done all of the work on every vehicle I have ever owned in my 58 years on this earth. I have gone as far as a complete rebuild of the engine and have not solved this problem. It finally got bad enough that the truck will not hardly move. I have given up. I had it towed to a guy on thursday that came highly recommended and will let you know the results. If this guy can't figure it out I will have no choice but to scrap the truck. God knows I hate to give up on anything but this has become untenable. If he can solve it I will blame myself for lack of knowledge and go on. If he can't I will swear off dodges forever.
  #27
Old 04-12-2009, 11:04 AM
lugnuts's Avatar
lugnuts
lugnuts is offline
First and foremost, have you checked the fuel pressure? What about the filter? Fuel injected motors don't stumble and gag when the pressure is low, they just run out of power from being lean.
Now then. Smallblock Mopars are hard on chains due to poor oiling,hence Mopar went to a double roller chain with a tensioner. It's also possible the outer ring on the balancer has slipped, and your timing marks are off.
Replace the chain, and here's how to check the balancer while you have the water pump and all the rest of the stuff outta the way. Knock the guts out of an old spark plug and JB Quick a bolt about 3" long in the shell. Screw the piston stop you've just made in the number one cyl. Gently roll the motor by hand until the piston hits the stop, mark the balancer. Roll the motor the other way until it hits the stop, mark the balancer. Remove the stop and measure between the marks. Top dead center [0 degrees on the balancer] should be half way between the marks. If it's right you're golden, if it's off replace the balancer.
  #28
Old 04-12-2009, 11:24 AM
charlie1935
I threaded my old plug then burred the threads on the bolt so it would stay where I put it. Can use it on any engine with the same plug threads. Only made it in 1967. LOL
Quick Reply: What are symptoms of loose timing chain??
